redirect console to uart1
I see that there are 2 uart with zynq: uart0, and uart1.
Is it possible to redirect console to uart1 already in u-boot ?
Ran
Yes, there are two UARTs- UART 0 and UART peripherals in Zynq PS section.
You can redirect console to see boot messages.
PV
PV
How to redirect uart1 to uart0?
Can send data to uart0 instead uart1 from outside of zynq board?
