songxin
sdk linker unable to place code section in bram
I'm trying to run C code without external DDR memory.
First, I add BRAM and AXI BRAM Controller with ARM.
Then, I tried to generate linker script to place those section to corresponding memory area.
However, I found it unable to place code section in BRAM area in the scroll bar.
is it forbidden to place code section in BRAM area?
Afterwards, I mannually edit the lscript.ld to place code section in BRAM area.
and the C code seems running fine.
But I'm not sure whether the mannually edited lscript.ld really works or not .
Could anybody help me with that
Thanks in advance.
Songxin
songxin
Finally I figured the problem out.
Manually edited linker script did take effect.
