romain.barraud
second SPI BUS (SPI1 PS or QSPI) can't be Initialized (Xil_assert)
hello everyone,
I encountered a strange problem with SPI1 (from PS) when I wanted implement a second SPI bus on a working project developed on a ZC702 board with Vivado 2018.3.
This project use already with succes SPI0 from PS. But when i add another SPI BUS (SP1 from PS7 or QSPI i have try the two possibility) the initialization of SPI1 or QSPI can't be done and stop at the level of XSpiPs_CfgInitialize() driver -> Xil_AssertNonvoid() -> Xil_assert().
So as i understand it look like a software mater but i don't know which one?
Some body as already encountered this problem?
romain.barraud
i have solved the matter of the initialization.
It was a software mistake from me. In regards of how i declare the instance handler as global variable and i don't now why it didn't like it. But now i declare it in local and now it passe CfgInitialize function and i can configure it.
But it remains a probleme with SP1 (PS)...
Selftests failed when in try it. so now i making face to an hardware matter i guess...
I have start a new project with only SPI0 and SPI1 from PS activate and SPi0 self test pass with success but not SPi1...
Somebody have an idea about what can i do for solve it?
