sysace_fopen() returns zero after 510 files
I have a loop in which each cycle writes a small file to the compact flash using xilfatfs library functions such as  sysace_fopen(), sysace_write() and sysace_fclose().
The problem is that after writing 510 files, sysace_fopen starts to return zero (no file created). Why is it happening after so many files have been written? I checked and there is still a lot of free space in the CF.
Best,
JM
Tags (4)
Re: sysace_fopen() returns zero after 510 files
See:
http://en.wikipedia.org/wiki/File_Allocation_Table
"The number of root directory entries available is determined when the volume is formatted, and is stored in a 16-bit signed field, defining an absolute limit of 32767 entries (32736, a multiple of 32, in practice). For historical reasons, FAT12 and FAT16 media generally use 512 root directory entries on non-floppy media."
-Brian
See:
-Brian
Correct, that was the problem. I wouldn't guess.
More, each sub folder can only have 62 files. Thank you alot.
The thing is that as more files are stored, the application becomes slower, I wonder why.. I started to notice after storing 2000 files. Do you have any idea why is this? Mabe sysace_fclose() is a little bit slow synching data with the device?
Best,
JM
