two interrupts from one custom core?
I have a custom core generating two interrupts, i.e., it drives IP2Bus_IntrEvent(0) andIP2Bus_IntrEvent(1). However, i don't understand how to attribute separate handlers using software. I only see one flag to register the handler in xparameters.h, which is like this:
    XIntc_RegisterHandler(XPAR_XPS_INTC_0_BASEADDR, XPAR_XPS_INTC_0_UNAV_SW_HW_INTERFACE_0_IP2INTC_IRPT_INTR, (XInterruptHandler)mee_handler, 0);
How do I separate the two interrupt signals i'm generating to use two handlers?
Best,
JM
Re: two interrupts from one custom core?
I have managed to understand this.
The custom core only provides an interrupt signal to the interrupt controller attached to the PLB, however the IPIF wrapper of the core possesses an interrupt controller which, in turn, has the ip interrupt control status register, acessible by software. Hence, the registered handler must check this register and see what interrupt source has generated the interrupt.
It now works fine.
Best,
JM
It now works fine.
Best,
JM
Hello, JM,
In my XPS project, I add Uart and EMAC to my project by the wizard. I enable all interrupt of these two peripherals. After generate and download bit stream to my board, I run the testapp software. But the testapp_peripheral does not run successfully with the Information which shows on the hyperterminal as follows:
Running Interrupt Test  for Ethernet_MAC ...
I check the port connection in System Assembly View. Uart's interrupt signal requires interrupt process through xps_intc_0. But EMAC's interrupt signal does not connect to PPC.
Is adding two peripeherals with interrupt enabled not unallowed?
How to deal with multiple interrupt sources?
Thank you very much!
Aaron.
Hello Aaron,
You can generate multiple interrupts with one peripheral or even multiple interrupts with various peripherals. Make sure you connect their interrupt output to the interrupt controller. You can accomplish this easily within the system assembly view->ports in EDK. The Interrupt controller attached to the PLB is responsible for the interrupt management to the processor, but since it has only one interrupt request line to the processor, it implements a multiplexer to go through all possible interrupt sources connected to it.
If using only one peripheral, you can connect the interrupt signal directly to the processor, however this can't be done when using different hardware interrupt sources.
In your case, if you are not changing anything, it should work by default, unless there is a bug. try to see with XMD where the testapp is stalling. For this, open XMD(Debug->XMD, and then run the software debugger (Debug->Software debugger).
Best,
JM
Im Trying 2 geht tow Different Interrupts from MyIPIF. The Ipif is connected to the INTC_0.
Thats the Way I added the Interrupt souces 2 the IP2Bus_IntrEvent:
  IP2Bus_IntrEvent(0) <= temp;
  IP2Bus_IntrEvent(1) <= temp1;
both are recognized by the Microblaze but when I try to figgure out wich of them occured I always get the same respone:
  - Enabling interrupts
Enabled REGISTERS 4
    SUCCESS!
Vector 20E00000
Some interrupt!
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
So I cant see if temp or temp1 occured,
Thats my C programm:
#include "xparameters.h"
#include "xbasic_types.h"
#include "xstatus.h"
#include "ma_timer_dual2.h"
#include "xintc.h"
Xuint32 my_timer;
unsigned int *my_timer_p =
         (unsigned int *) XPAR_MA_TIMER_DUAL2_0_BASEADDR;
// INTERRUPT HANDLER FUNCTION
void MA_TIMER_DUAL2_Intr_Handler(void * baseaddr_p)
  static Xuint32 led_data;
  Xuint32 baseaddr;
  Xuint32 IpStatus;
  baseaddr = (Xuint32) baseaddr_p;
    xil_printf("Some interrupt!\r\n");
  // Get the timer interrupt status
  IpStatus = XIntc_mGetIntrStatus(MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
    xil_printf("Vector %x\r\n",IpStatus);
    //MA_TIMER_DUAL2_mWriteReg(XPAR_MA_TIMER_DUAL2_0_BASEADDR, MA_TIMER_DUAL2_INTR_IPISR_OFFSET, IpStatus);
  // If timer caused the interrupt then switch LEDs
  Xuint32 status;
  status = MA_TIMER_DUAL2_mReadReg(XPAR_MA_TIMER_DUAL2_0_BASEADDR, MA_TIMER_DUAL2_INTR_CNTRL_SPACE_OFFSET);
  xil_printf("Vector %x\r\n",status);
  //XIntc_Acknowledge();
  if (IpStatus){
// MAIN FUNCTION
int main (void)
  Xuint32 status;
  Xuint32 IpStatus;
  // REGISTER INTERRUPT HANDLER
  xil_printf("  - Registering interrupt handler\r\n");
    XPAR_XPS_INTC_0_MA_TIMER_DUAL2_0_IP2INTC_IRPT_INTR,
    MA_TIMER_DUAL2_Intr_Handler,
    (void *)XPAR_MA_TIMER_DUAL2_0_BASEADDR);
  // ENABLE INTERRUPTS
  xil_printf("  - Enabling interrupts\r\n");
  // Enable INTC interrupts
  XIntc_mMasterEnable(XPAR_XPS_INTC_0_BASEADDR);
  XIntc_mEnableIntr(XPAR_XPS_INTC_0_BASEADDR,
    XPAR_MA_TIMER_DUAL2_0_IP2INTC_IRPT_MASK);
  // Enable timer interrupts
  MA_TIMER_DUAL2_EnableInterrupt(my_timer_p);
  // Enable Microblaze interrupts
  microblaze_enable_interrupts();
  MA_TIMER_DUAL2_mWriteReg(XPAR_MA_TIMER_DUAL2_0_BASEADDR, MA_TIMER_DUAL2_INTR_DIER_OFFSET, 4/*0xFFFFFFFF*/);
  IpStatus = MA_TIMER_DUAL2_mReadReg(XPAR_MA_TIMER_DUAL2_0_BASEADDR,MA_TIMER_DUAL2_INTR_DIER_OFFSET);
    xil_printf("Enabled REGISTERS %x\r\n",IpStatus);
  xil_printf("    SUCCESS!\r\n");
  while(1){
It seems that your handler is being called in inf loop.
Clear the interrupt at the end of the handler by writing back lpstatus. Ex:
    xil_printf("User logic interrupt! \n\r");
    IpStatus = FE_CF_INTERFACE_mReadReg(baseaddr, FE_CF_INTERFACE_INTR_IPISR_OFFSET);
    FE_CF_INTERFACE_mWriteReg(baseaddr, FE_CF_INTERFACE_INTR_IPISR_OFFSET, IpStatus);
And see if the interrupt status register starts to change.
Best,
JM
thx 4 your help ...
I modified my ISR
but I still geht the same Messages:
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
Some interrupt!
Vector 20E00000
Vector 0
The new ISR:
  Xuint32 baseaddr;
  Xuint32 IpStatus;
  Xuint32 status;
  IpStatus = MA_TIMER_DUAL2_mReadReg(baseaddr, MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
  MA_TIMER_DUAL2_mWriteReg(baseaddr, MA_TIMER_DUAL2_INTR_IPISR_OFFSET, IpStatus);
  if (IpStatus){
Best,
/me
A couple of things:
1) I'm not sure about XIntc_mGetIntrStatus to read the status register. Use
instead of
2) Also i don't see why you read status and lpStatus and print both as Vector XX..
3) Make sure the base address is being passed into the handler.
4) Go into the drivers/your_custom_core/src to get an example on how you can correctly activate and manage interrupts for your custom core. You should use your driver auto-generated functions to correctly initialize the interrputs.
thx ...
the autogenerated handler is quite useful.
I cleand the code acording to your suggestions, but the problem is still the same ... no Difference between the Interrupts.
    SUCCESS!
Device Interrupt! DISR value : 0x00000000
Code:
#include "xintc.h"
  Xuint32 baseaddr;
  Xuint32 IntrStatus;
Xuint32 IpStatus;
   * Get status from Device Interrupt Status Register.
  IntrStatus = MA_TIMER_DUAL2_mReadReg(baseaddr, MA_TIMER_DUAL2_INTR_DISR_OFFSET);
  xil_printf("Device Interrupt! DISR value : 0x%08x \n\r", IntrStatus);
   * Verify the source of the interrupt is the user logic and clear the interrupt
   * source by toggle write baca to the IP ISR register.
  if ( (IntrStatus & INTR_IPIR_MASK) == INTR_IPIR_MASK )
// MAIN FUNCTION
int main (void)
  Xuint32 status;
  Xuint32 IpStatus;
  MA_TIMER_DUAL2_EnableInterrupt((void *)XPAR_MA_TIMER_DUAL2_0_BASEADDR);
  while(1){
Tags (3)
In this case you should read from the IPIF wrapper interrupt controller to see what is the source of the core interrupt, not the device interrupt.
Try this:
 IntrStatus = XIo_In32(BASE_ADDR + MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
instead of
Best,
JM
    SUCCESS!
still the same problem .....
I also tried
  IntrStatus = MA_TIMER_DUAL2_mReadReg(baseaddr, MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
  //IntrStatus = XIo_In32(baseaddr_p + MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
without succsess.
Base and Highadress are the same in Xparameters and in the XPS .......
thats the full XPS projekt .....
http://mac.piffpaffpuff.net/timertest.zip
Best,
Tobias
Using the Device ISC is ok?
Best
No, try as i told you:
// Read from the IPIF wrapper interrupt controller to see what is the source of the core interrupt
IpStatus = XIo_In32(BASE_ADDR + UNAV_SW_HW_INTERFACE_INTR_IPISR_OFFSET);
where
#define BASE_ADDR XPAR_MA_TIMER_DUAL2_0_BASEADDR
(Confirm that XPAR_MA_TIMER_DUAL2_0_BASEADDR is the baseaddr on your xparameters.h)
lpStatus must not be zero, it has to have the value (1, 2) of the tinterrupt that triggered the ISR. This prompts me that you are not getting the value correctly.
Best,
JM
also returns:
    SUCCESS!
Thaks for still helping me JM
do you think I should rebuild the Projekt?
C Code:
#include "xintc.h"
  Xuint32 baseaddr;
  Xuint32 IntrStatus;
Xuint32 IpStatus;
  //IntrStatus = MA_TIMER_DUAL2_mReadReg(baseaddr, MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
// MAIN FUNCTION
int main (void)
  Xuint32 status;
  Xuint32 IpStatus;
  while(1){
Xparameters:
/* Definitions for peripheral MA_TIMER_DUAL2_0 */
#define XPAR_MA_TIMER_DUAL2_0_DEVICE_ID 0
#define XPAR_MA_TIMER_DUAL2_0_BASEADDR 0xC3C00000
#define XPAR_MA_TIMER_DUAL2_0_HIGHADDR 0xC3C0FFFF
Read the posts carefully.
It is possible that the base address is not being correctly passed to the handler, so i suggested you to pass it hardcoded:
where
instead of using baseaddr_p. As i said, lpStatus cannot be zero, it is possible that you are not reading this value correctly.
Check in xparameters.h if XPAR_MA_TIMER_DUAL2_0_BASEADDR is exactly your base address variable.
I also assume that you have these included:
// Generic needed libraries
#include "xintc_l.h"
Best,
JM
I checked the includes everything seems to be ok there ...
I used
  IntrStatus = XIo_In32((void *)XPAR_MA_TIMER_DUAL2_0_BASEADDR + MA_TIMER_DUAL2_INTR_IPISR_OFFSET);
But I still get Zerros all the time ..... no other Value ....
includes:
code:
:smileyhappy:
I think I found the Problem .... but now I have another one .....
I made the mistake to tell the XPS in the create peripheral dialoge to pass through the interrupts ....
So everytime I wanted to look @ the interrupt source it was already 0 again.
And I dont got an DISR Value. No I get One.....
But now im in an Interrupt loop
To solve that I tried
*Using the Default Interrupt Header
and got:
Device Interrupt! DISR value : 0x00000004
*Hardcode the BASEADDRESS
and got:
*Using
IntrStatus = XIo_In32((void *)XPAR_MA_TIMER_DUAL3_0_BASEADDR + MA_TIMER_DUAL3_INTR_IPISR_OFFSET);
instead of  the Default:
IntrStatus = MA_TIMER_DUAL3_mReadReg(XPAR_MA_TIMER_DUAL3_0_BASEADDR, MA_TIMER_DUAL3_INTR_DISR_OFFSET);
and got:
Device Interrupt! DISR value : 0x00000003
*READ OUT DISR and IPISR
and got:
Device Interrupt! IPISR value : 0x00000002
*Clear the DISR
with  MA_TIMER_DUAL3_mWriteReg(XPAR_MA_TIMER_DUAL3_0_BASEADDR, MA_TIMER_DUAL3_INTR_DISR_OFFSET, IntrStatus);
But the Register Wont Change .... its still Device Interrupt! DISR value : 0x00000004
Code Derfault Header:
void MA_TIMER_DUAL3_Intr_DefaultHandler(void * baseaddr_p)
  Xuint32 baseaddr;
  Xuint32 IntrStatus;
Xuint32 IpStatus;
  IntrStatus = MA_TIMER_DUAL3_mReadReg(baseaddr, MA_TIMER_DUAL3_INTR_DISR_OFFSET);
    IpStatus = MA_TIMER_DUAL3_mReadReg(baseaddr, MA_TIMER_DUAL3_INTR_IPISR_OFFSET);
    MA_TIMER_DUAL3_mWriteReg(baseaddr, MA_TIMER_DUAL3_INTR_IPISR_OFFSET, IpStatus);
My last code, Default Header + modifications:
#include "ma_timer_dual3.h"
#include "xintc.h"
void MA_TIMER_DUAL3_Intr_Handler(void * baseaddr_p)
  Xuint32 baseaddr;
  Xuint32 IntrStatus;
Xuint32 IpStatus;
  //baseaddr = (Xuint32) baseaddr_p;
  //IntrStatus = MA_TIMER_DUAL3_mReadReg(XPAR_MA_TIMER_DUAL3_0_BASEADDR, MA_TIMER_DUAL3_INTR_DISR_OFFSET);
  xil_printf("Device Interrupt! IPISR value : 0x%08x \n\r", IntrStatus);
  IntrStatus = XIo_In32((void *)XPAR_MA_TIMER_DUAL3_0_BASEADDR + MA_TIMER_DUAL3_INTR_DISR_OFFSET);
    IpStatus = MA_TIMER_DUAL3_mReadReg(XPAR_MA_TIMER_DUAL3_0_BASEADDR, MA_TIMER_DUAL3_INTR_IPISR_OFFSET);
    MA_TIMER_DUAL3_mWriteReg(XPAR_MA_TIMER_DUAL3_0_BASEADDR, MA_TIMER_DUAL3_INTR_IPISR_OFFSET, IpStatus);
  xil_printf("Device Interrupt! IPISR is now value : 0x%08x \n\r", IntrStatus);
  xil_printf("Device Interrupt! DISR is now value : 0x%08x \n\r", IntrStatus);
// MAIN FUNCTION
int main (void)
  Xuint32 status, Status;
  Xuint32 IpStatus;
  XIntc InterruptController;
    XPAR_XPS_INTC_0_MA_TIMER_DUAL3_0_IP2INTC_IRPT_INTR,
    MA_TIMER_DUAL3_Intr_Handler,
    (void *)XPAR_MA_TIMER_DUAL3_0_BASEADDR);
  XPAR_MA_TIMER_DUAL3_0_IP2INTC_IRPT_MASK);
  MA_TIMER_DUAL3_EnableInterrupt((void *)XPAR_MA_TIMER_DUAL3_0_BASEADDR);
  while(1){
It looks like an Problem in my userlogic ... I tryed the default template without modifikations and it worked ....
But my logic also looks ok in behavoral simulation ....
:smileysad:
There are vhdl instructions that are not synthesizable but can be simulated. Check your design to see if you are not using some of these.
example:
x <= '1' after 2ns.
Best,
JM
ok i checked this i think my Code is Quite Synthesizable.
I created the template with the Priority Encoder Option, the Use Device ISC Option and Rising Edge Detect.
In the Import Dialoge I also choose the Rising Edge Option for my Interrupt Signal (IP2Bus_IntrEvent).
Thats the way I modiefied the default Template
  -- Example code to generate user logic interrupts
  -- Note:
  -- The example code presented here is to show you one way of generating
  -- interrupts from the user logic. This code snippet infers a counter
  -- and generate the interrupts whenever the counter rollover (the counter
  -- will rollover ~21 sec @50Mhz).
  INTR_PROC : process( Bus2IP_Clk ) is
    constant COUNT_SIZE   : integer := 30;
    constant ALL_ONES     : std_logic_vector(0 to COUNT_SIZE-1) := (others => '1');
    variable counter      : std_logic_vector(0 to COUNT_SIZE-1);
  begin
    if ( Bus2IP_Clk'event and Bus2IP_Clk = '1' ) then
      if ( Bus2IP_Reset = '1' ) then
        counter := (others => '0');
        intr_counter <= (others => '0');
      else
        counter := counter + 1;
         if ( counter = ALL_ONES ) then
          temp <= '1';
         else
          temp <= '0';
        end if;
      end if;
    end if;
      end process INTR_PROC;
    INTR_PROC2 : process( Bus2IP_Clk ) is
    constant COUNT_SIZE   : integer := 20;
  begin
      else
          temp1 <= '1';
         else
          temp1 <= '0';
        end if;
      end if;
    end if;
  end process INTR_PROC2;
  IP2Bus_IntrEvent(2 to 4) <= (others => '0');
but it causes interrupt Looping
You don't need the device ISC option since all your interrupts pass through the user logic. This can be messing up with your interrupt control register read.
Jear it seems to work now ...
Am I just an Idiot? or is really such hard to get into the whole thing?
How to explain some one It took me nearly 2 Weeks to get into the interrupt thing?
thx 4 your help ...
Nice. No, it is fairly ok to get some time to figure out some things.
By the way, was the Device ISC the reason of your last issue?
Best,
JM
yes ...
