rsclancy
uBlaze, ethernet, interrupts, and HSI 55-1442 BSP failed
Running Vivado 2015.4.1 64 Bit on Windows 7
SW Build 1431336 on Fri Dec 11 14:52:45 MST 2015
IP Build 1427053 on Mon Dec 7 12:56:29 MST 2015
Running SDK 2015.4
I am getting the same errors as in post:
https://forums.xilinx.com/t5/Welcome-Join/ERROR-GENERATING-BSP-SOURCES-FAILED-TO-GENERATE-BSP-ERROR-HSI-55/m-p/676100#M33529
The solution there was to make sure the proper libraries are installed. What is the solution on windows?
Robert
16:36:49 INFO : Launching XSDB server: xsdb.bat C:/Xilinx/SDK/2015.4/scripts/xsdb/xsdb/xsdb-server.tcl
16:36:50 INFO : XSDB server has started successfully.
16:36:50 INFO : Processing command line option -hwspec C:/Working/VC707/SimpleBlaze/Vivado/src/hardware/design_1_wrapper.hdf.
16:36:51 INFO : Checking for hwspec changes in the project design_1_wrapper_hw_platform_0.
16:40:53 ERROR : (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specified for 'object'.
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_axiethernet_v5_0::generate : ERROR: [Common 17-161] Invalid option value '' specified for 'object'.
while executing
"get_property IP_TYPE $pname_type"
("foreach" body line 4)
invoked from within
"foreach intr_sink $intc_port {
set pname_type [::hsi::utils::get_connected_intr_cntrl $target_periph $intr_sink]
if {$pname_type != ..."
("foreach" body line 9)
invoked from within
"foreach intr_port $interrupt_port {
set interrupt_signal_name [get_property NAME $intr_port]
set intc_port [get_pins -of_objects $targ..."
(procedure "xdefine_dma_interrupts" line 20)
invoked from within
"xdefine_dma_interrupts $file_handle $target_periph $device_id $canonical_tag $dmarx_signal $dmatx_signal"
("foreach" body line 88)
invoked from within
"foreach periph $periphs {
set p2p_periphs [list]
set periph_name [string toupper [get_property NAME $periph]]
# Get all point2point b..."
(procedure "xdefine_axi_target_params" line 17)
invoked from within
"xdefine_axi_target_params $periphs $file_handle"
(procedure "xdefine_axiethernet_include_file" line 47)
invoked from within
"xdefine_axiethernet_include_file $drv_handle "xparameters.h" "XAxiEthernet""
(procedure "::sw_axiethernet_v5_0::generate" line 3)
invoked from within
"::sw_axiethernet_v5_0::generate axi_ethernet_0"
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
16:40:53 ERROR : (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.
16:40:53 ERROR : Error generating bsp sources: Failed in generating sources
sampatd
I suspect that the issue could be with your interrupt connections. How does your block diagram look like?
pvenugo
Could you share the workspace to look into the issue?
Praveen
sampatd
rsclancy
Attached is a pdf of the block design. The interrupts are concatenated before being connected to the AXI Interrupt Controller.
I've attached the address map as well, fwiw.
Robert
rsclancy
Preveen,
The SDK workspace, the Vivado project, or both?
Robert
rsclancy
When trying to create a BSP for FreeRTOS 8.2.3, it seems like the SDK can't quite suss out what/where the interrrupt controller is. I say this because the freertos823_xilinx parameter SYSINTC_SPEC is reported as '*'.
It seems to figure out stdin and stdout correctly.
rsclancy
Indeed, it was a missed interrupt connection on the DMA block, not the 1/2.5 Ethernet assembly. Reading the tcl source found at:
c:/Xilinx/SDK/2015.4/data/embeddedsw/XilinxProcessorIPLib/drivers/axiethernet_v5_0/data/axiethernet.tcl
was helpful in chasing down why the BSP generate function was unhappy. That pointed me in the direction of the DMA block and the offending unconnected interrupt lines mm2s_introut and s2mm_introut.
I may be having the same issue, but do have all the DMA and Ethernet interrupts tied correctly
16:33:00 ERROR       : Error generating bsp sources: Failed in generating sources
16:33:00 ERROR       : Failed to generate sources for BSP project EchoServer_bsp
org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details.
       at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178)
       at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163)
       at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131)
       at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
       at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135)
       at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
16:34:42 ERROR       : Error refreshing build settings on referencing application projects.
Additional details on interrupts
