uart
Hi everyone
I'm developing an application in vxworks. In this application I use uart in polling mode for reading and writing.
The problem is that when I disable uart interrupt using "intDisable" command, uart generally does not work in polling mode.
The question is whether this is normal? Why uart does not work in polling mode if I disable it's interrupts.
Thanks for the tips of your
