ultrascale A53 L2 cache
Does the A53 L2 cache can be allocated between different cores , like zynq 7000 by cache lockdown?
Hi dfx28@ntesec.com.cn ,
Like Zynq-7000 device in Zynq US+ L2 SCU arbitrates L2 request between cores.
Praveen
dfx28@ntesec.com.cn
Lockdown can be done as specified in section D.4.4.10 of
https://developer.arm.com/docs/ddi0487/latest/arm-architecture-reference-manual-armv8-for-armv8-a-architecture-profile
It is "implementation defined" and I didn't see anything related to this in the UltraScale+ Register Map (lots of registers so I may have missed it).
@pvenugo : you've indicated the SCU handles this. Could you pinpoint the registers to set up as they are not A53 native?
