Anonymous
Not applicable
usb transceiver(TIUSB1210) is not working on zynq 7000 based custom board
I am unable to bring up usb transceiver. I want to use it as usb gadget ethernet, I could make it up on zed board, but not on custom board. Please see below for the details :
Hardware details :
FPGA : Zynq 700 Soc
USB transceiver : TIUSB1210
Tool : Vivado 2016.3
software details :
Running linux OS version 4.6 on zynq 7000 SoC.
Here below I have put a snippet of both zed board and custom board kernel print for TUSB1210.
Zed board prints :
hci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
dummy_hcd dummy_hcd.0: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd.0: Dummy host controller
dummy_hcd dummy_hcd.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Custom Board prints :
ci_hdrc ci_hdrc.0: unable to init phy: -110
ci_hdrc: probe of ci_hdrc.0 failed with error -110
I have attached the device tree of both.
Please shed some light on this issue.
Shiva Shankar K.
I'm having the same issue with different usb-phy and different Petalinux version (2017.2).
Have you found a solution for it?
