use of block memory generator
Is it possible to use BRAM in standalone mode,to connect to axi controller and my HLS created IP.Or is there any other way to do so.
What I am doing is giving a data to HLS IP and getting calculated with it using BRAM.
Thanks in advance
regards,
Sarika
Re: use of block memory generator
hi @sarika93 ,
i didnt get the idea properly.
"What I am doing is giving a data to HLS IP and getting calculated with it using BRAM."
how you are giving data to HLS ip? Are you planning to use AXI controller to collect data from HLS IP and storing it in BRAM?
regards,
Reshma
You got me right.This is what I wanted to say,giving data and getting it back both using controller.
