using the OpenCV library with Zynq
Hi all,
I use the Zc702 board and I want to run an example which uses the OpenCV library.
I found this document http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/SDK_Doc/tasks/sdk_t_opencv_template.htm but it dosn't work and an error appear to me :
/opencv2/video/background_segm.hpp:47:16: fatal error: list: No such file or directory
compilation terminated.
make: *** [src/helloworld.o] Erreur 1
Please, How can I find the right version of OpenCV dedicated to the Zynq 7000 and How can I install it to use it on SDK?
Mokhtar
Check if you have the OpenCV library in the following location of SDK Install?
$SDK_Install\sw\ThirdParty\opencv?
--Hem
Yes I Checked it and it's in the right  location.
Mokhtar
