using usb port on virtex4- ML402 board
hi,
this is pertaining to using usb port available on ML 402 Xilinx board(virtex4 SX35).
we are facing problems in carrying out the data transctions via usb port.though we
have gone through the manuals of cypress CY7C67300(usb controller) available on the
board but are yet unable to comprehend the same.kindly help us out.
with warm regards
rimi reddy
student(NIT)
If you are using EDK then you can refer to XAPP982.
Hem.
