sf
vcu118 board read/write sd card
I was planning to do a fpga design for reading/writing data from sd card on a vcu118 then I found this paragraph in manual.
The VCU118 board includes a secure digital input/output (SDIO) interface allowing the
U111 XC7Z010 Zynq-7000 SoC system controller access to general purpose nonvolatile
micro-SD memory cards and peripherals. The micro-SD card slot is designed to support
50 MHz high speed micro-SD cards. The SD card is not accessible by the U1 XCVU9P FPGA
and is not an FPGA configuration option.
Does it basically mean I can not do what I want?
The manual does not mention anything about the sd card pin number but I find some information in schematic, like SDIO_CMD is pin B10 and SDIO_CLK is B7.
But the schematic document appears to say the sd command is single direction which I know is not true, as it should be bidirectional.
Do you guys know how vcu118 supports sd card? Can I achieve my plan with vcu118? If no, any other good options of external storage device works with vcu118, to replace sd card?
Tags (2)
anatoli
Hello @sf ,
What exactly do you need to do? Are you looking to program the board from SD, or just pull files off a card?
As you've already noticed from the below comment, on VCU118 board SD-Card programming is not supported.
For previous ultrascale device evaluation boards it was supported through SCUI utility.
Let's see if other users/experts can provide you with an alternative solution (if any) for you to achieve what is required in your case.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
sf
Hi anatoli,
just pull files off a card. Basically my fpga design has to read/write sd card.
