fkharrat
vid_in_axi4s delay problem
hello,
I'm using the vid_in_axi4s IP,  it work but tuser is delayed one line ( See attached )
Thank you in advance for your answer
fkharrat
part of my design
muzaffer
please show vid_active_video signal too.
fkharrat
thanks you for your reply,
vid_active_video = FrameValid and LineValid ( i see that in this forum)
fkharrat
Please someone help me !!
josephsamson
Your waveform shows Frame Valid and Line Valid, and you say that you're using those signals to form the active video signal. However, your block diagram shows that you're using HSync and VSync as your synchronizing signals, with HBlank and VBlank tied off. Why not invert Frame Valid and use it as VBlank and invert Line Valid and use it as HBlank? That has always worked for me.
Joe Samson
