vivado2017_2:some boards did not ppear in the project device
i have just download and install vivado 2017.2
when opening the project device i can't find some boards such as ARTIX 7 50T /micro zed boards in the list of boards supported
-please note that i checked all the  devices when installing vivado
-please have a look to the screenshoot attached that list all the boards supported
I would like to know whether i could add a defined board to the list displayed like micro zed board..?
thank you.
Best Regards
Re: vivado2017_2:some boards did not ppear in the project device
Hi @adhouib,
Yes you can add custom boards or board from other vendors. For example for the Arty 7 50T:
Download the vivado board file from Digilent website - Arty 7 50T page (link)
Follow the tutorial to add it to vivado (link) - Basically just paste the files to the Vivado installation folder
Hope that helps
Florent
Florent
Hi @adhouib,
Hope that helps
Florent
Florent
Voyager
Voyager
Hey @adhouib,
The AVNET Board Definition Files include the MicroZed.
Best,
Herbert
-------------- Yes, I do this for fun!
thank you for your responses.
Concerning ARTIX 7 50T the board file is provided in the avnet web site (link)
Best Regards.
Voyager
Voyager
You're welcome!
All the best,
Herbert
