Advisor
Advisor
what if I do not connect the SD WP pin to (E)MIO
If I don't connect the SD card controller's Write Protect pin to an external MIO or EMIO pin, is the SD card 'write protected' or not from the point of view of the controller (asuming the card's own write protect switch is set to 'write enabled')?
So in the screenshot below, if I would remove MIO pin 50 by deselecting 'Write protect', would the SD card be writable? That would save me an MIO pin.
Also I know I can connect it to EMIO, and add a constant '0' to the pin (in my design I need the SD to be writable because I boot the kernel from the SD card, and it seems to expect a writable SD card). But I'm not sure if that's the best way for me, so I'd prefer to just leave it disconnected from the MIO.
So in other words, has the SD controller an internall weak pull-down or pull-up on this pin, so that - if left unconnected it takes a defined state?
Actually, I have the same question for the CD pin :-)
check this ARs
http://www.xilinx.com/support/answers/61064.html
http://zedboard.org/sites/default/files/ZedBoard_HW_UG_v1_1.pdf
Thanks and Regards
Balkrishan
I believe that using EMIO with a constant '0' is the only option, but I'm curious to hear otherwise.
check this ARs
Thanks and Regards
Balkrishan
Advisor
Advisor
thanks @balkris, AR# 61064 is clear on that : the signal is required for the SD controller.
This info should added to the TRM, or at least the AR should be referred to in the TRM.
I ended up connecting WP to EMIO, and connect this EMIO to a constant IP block with '0' to permanently write enable the SD card.
When CD is not enabled in the Zynq peripheral configuration the FSBL could also set Card_detect_signal_detection in the Register Host_control_Power_control_Block_Gap_Control_Wakeup_control register and set Card_Detect_Test_Level as well. Unfortunately that is not what is generated. And there seem to be no such registers bits for WP.
Are these signals required for when eMMc is used also ?
I noticed that in picozed the CD is internally connected to GND
Is the WP also needed in case of eMMC ?
Community Manager
Community Manager
You can connect it to Gnd inside PL section
AFAIK they are required for eMMC as well. It's the host controller and/or software driver that needs them. And I don't think it knows of any difference between eMMC and (u)SD.
picozed only seems to use CD ?
Advisor
Advisor
@teroki, did you find an answer to the question if eMMC needs a similar WP line connected to GND? (through EMIO for example?)
@balkris, do you have an answer on this ? It's not mentioned in the AR (only for SD card)
I got this answer
>>Since Vivado 2015.2, CD and WP are not necessary with the SDIO controller.
But we decides to put them both connected in our HW.
That is not my experience if you want to write to it from linux.
