lidaxjtu
which fpga supports the fpu ip core?
except  virtex-4 FX, which fpga can support the fpu ip core,especially with microblaze core ?
does XC3S500E ?
And the publication words says " spartan3E-fpga can  build compact DSP ", I don't understand how to use the available ip core to build the compact DSP?
Anonymous
Not applicable
The Spartan 3E does support the FPU for the microblaze core.  When you run through the Base System builder with our EDK tools, you can select the FPU as an option if you would like to use this in your EDK design with microblaze.
Anonymous
Not applicable
The compact DSP that is mentioned in the publication just means that some of the DSP cores such as MAC engines or parallel FIR filters will be more compact using the 18x18 multipliers rather than implementing the cores in regular fabric.  It is just stating that the way that the filter is actually built in the part is more "compact".
lidaxjtu
So I still can select the FPU enable in my edk project ( xc3s500e), and I can also use the float-point operation in my c programme.
without adding the fpu ip core.
do i understand right?
goran
MicroBlaze has it's own FPU core which don't exists as a seperate IP core.
It's not the same as the standalone FPU ip core which only works for PPC.
MicroBlaze FPU core works for all FPGA architectures that MicroBlaze supports.
So if you can target MicroBlaze, you can also get the MicroBlaze FPU core.
Göran
