xapp1167 input video error
I am implementing reference design of XAPP1167 on Zc702. The design works fine when we use the video generated by Test Pattern Generator. However, it does not open decoded video provided with design folder. Even when I don't change anything and just copy the original files located in the zip file, I get this error message when I try to open input video file:
 Incorrect input: open video file (input_video) failed.
 Need video file "input_video" on SD card.
 Turning on TPG input.
The video file is located in the same directory with the application. It is really suprising to get this error even though I simply use the files provided with reference design zip.
Best,
