Anonymous
Not applicable
zcu102 pcie linux driver doesn't work
I am using a zcu102 board, when using the pre-built linux image from http://www.wiki.xilinx.com/Zynq+2016.2+Release, I found the PCIE doesn't work.
I also git checkout latest linux source from https://github.com/Xilinx/linux-xlnx, and still failed to probe PCIE.
Below is the env settings:
board: zcu102
uboot: U-Boot 2016.01 (Jun 10 2016 - 07:24:48 +0530) Xilinx ZynqMP ZCU102
kernel: latest linux source from github
dtb: linux-xlnx/arch/arm64/boot/dts/xilinx/zynqmp-zcu102.dtb
I attach the boot log file, we can see in the boot period, there is no any output related with PCIE
Please check whether the information in the below AR helps
https://www.xilinx.com/support/answers/68145.html
Anonymous
Not applicable
Thanks for your reply.
I think PetaLinux is not same as Linux, right?
So, my question is: does zcu102 linux released at https://github.com/Xilinx/linux-xlnx support PCIE Root Port?
I can't answer your PCIe question but just so you know petalinux is just the build/configuration system.   It could build linux from any git repo but obviously most people use the Xilinx repo.
jeff
