02-24-2021 08:26 PM
amba axi protocol specification explains axi signal ARVALID like as
Read address valid. This signal indicates, when HIGH, that the read address and control
information is valid and will remain stable until the address acknowledge signal,
ARREADY, is high.
1 = address and control information valid
0 = address and control information not valid.
i can't understand this sentence
means ARVALID must stable between clock edge, or other timing.
because there is no acknowledge signal (ARACK?, etc...)
also i can't find timing information on vivado axi interconnect manual .
what is correct timing keep ARVALID signal to high.
02-26-2021 09:27 AM
Hi @sanghyun_kim,
The phrase should be read to the end:
will remain stable until the address acknowledge signal, ARREADY, is high.
This means the acknowledge signal in this case is "ARREDY".
From the AXI spec (plz double check that you are using the latest version of the spec):
"Once VALID is asserted it must remain asserted until the handshake occurs, at a rising clock edge at which VALID and READY are both asserted."
02-26-2021 09:27 AM
Hi @sanghyun_kim,
03-01-2021 04:30 PM
also i missed this.
ACLK Clock source Global clock signal. All signals are sampled on the rising edge of the global clock.
all signal sampled on the pos-edge.
slave may assert arready after pos-edge.
