I am having some very unusual behaviour from the 64-bit Microblaze implementation when assigning a 64bit value to a u64 variable.
In Vivado 2019.1 I created a simple Microblaze design with the Microblaze configured in 64-bit. In SDK 2019.1 I then perform the following assignments as a test, with the corresponding results in the 'Variables' window.
uint64_t Data_64;
Data_64 = 0xFFFF_FFFF_FFFF_FFFF; ('Variables' result : 0xFFFF_FFFF_FFFF_FFFF) - Correct
Data_64 = 0xFFFF_FFFF_FFFF_0000; ('Variables' result : 0xFFFF_FFFF_FFFF_0000) - Correct
Data_64 = 0xFFFF_FFFF_0000_FFFF; ('Variables' result : 0x0000_0000_0000_FFFF) - Error
Data_64 = 0xFFFF_0000_FFFF_FFFF; ('Variables' result : 0xFFFE_0000_FFFF_FFFF) - Error
Data_64 = 0x0000_FFFF_FFFF_FFFF; ('Variables' result : 0x0000_FFFE_FFFF_FFFF) - Error
Data_64 = 0x0000_0000_0000_0000; ('Variables' result : 0x0000_0000_0000_0000) - Correct
Data_64 = 0x0123_4567_89AB_CDEF; ('Variables' result : 0x0123_4566_89AB_CDEF) - Error
Data_64 = 0x0000_0004_0000_0000; ('Variables' result : 0x0000_0000_0000_0000) - Error
Clearly certain values are not being assigned correctly to the variable. If I use the same code for addressing I end up addressing sections of the program itself and obviously the program freezes. Especially for "0x0000_0004_0000_0000" which is the base address for my DDR4 memory interface.
Can anybody indicate what is the problem here and how I can resolve it?
