Observer alberto_p
AC701 SPI bus on flash error
Dear all,
I am having problem in using the SPI bus to read the flash on the AC701 board.
My design is shown on the picture attached : I use the jtag-to-axi to talk with the axi-quad-spi working in standard mode (no FIFO).
The code I use on the TCL console is here:
# Create and object reset AXI QUAD SPI CORE
create_hw_axi_txn -address 44A00040 -data 0000000A -type write RST_QSPI [get_hw_axis hw_axi_1]
# SPI Control reg SET
create_hw_axi_txn -address 44A00060 -data 000001FE -type write SET_CTRL_QSPI [get_hw_axis hw_axi_1] -force
# SPI Control reg GET
create_hw_axi_txn -address 44A00060                -type read  GET_CTRL_QSPI [get_hw_axis hw_axi_1] -force
# SPI Read Status
create_hw_axi_txn -address 44A00064                -type read STATUS_QSPI [get_hw_axis hw_axi_1] -force
# SPI Write data READ ID COMMAND
create_hw_axi_txn -address 44A00068 -data 9E000000 -type write READID_QSPI [get_hw_axis hw_axi_1] -force
# SPI CS @ 0
create_hw_axi_txn -address 44A00070 -data 00000000 -type write CS_QSPI [get_hw_axis hw_axi_1] -force
#Remove Ihibit
create_hw_axi_txn -address 44A00060 -data 0000009E -type write RM_INH_QSPI [get_hw_axis hw_axi_1] -force
# SPI CS @ 1
create_hw_axi_txn -address 44A00070 -data 00000001 -type write RM_CS_QSPI [get_hw_axis hw_axi_1] -force
# SPI READ DATA
create_hw_axi_txn -address 44A0006C                -type read READ_QSPI [get_hw_axis hw_axi_1] -force
# TX FIFO
create_hw_axi_txn -address 44A00074                -type read TX_QSPI [get_hw_axis hw_axi_1] -force
# RX FIFO
create_hw_axi_txn -address 44A00078                -type read RX_QSPI [get_hw_axis hw_axi_1] -force
# RUN reset
run_hw_axi RST_QSPI
# RUN ctrl
run_hw_axi SET_CTRL_QSPI
# RUN ctrl
run_hw_axi GET_CTRL_QSPI
# RUN status
run_hw_axi STATUS_QSPI
# RUN read id
run_hw_axi READID_QSPI
# RUN cs
run_hw_axi CS_QSPI
#Remove inhibit
run_hw_axi RM_INH_QSPI
# RUN cs
run_hw_axi RM_CS_QSPI
# Inhibit transition again
# RUN read data
run_hw_axi READ_QSPI
If I run it the first time, I obtain on the oscilloscope what is shown on Fig. run0: it looks like the data out (pink signal) starts before spi_CLK (yellow); but if I run it again (immediately after, with no switch-off, switch-on, just the same code again), I obtain what is shown on run1 (which is correct: in the second case, the I can read the flash ID).
Do you know what is going on?
Thanks for your help.
Regards.
