Observer monica_4780
APU to PL Inter Process Interrupt
I have synthesized a softcore processor (Cortex-M3) in the Programmable logic. I want to carry out inter process communication between APU (cortex-A53) and PL softcore (cortex-M3) using PL IPI channel. Under "Advanced Configuration" for Zynq Ultrascale in vivadao, I have connected the channel 7 IPI to S_AXI_HP0_FPD. However, the processor is not able to receive any interrupts.
Is the any example available for the implementation of IPI in PL?
Any lead would be helpful.
Re: APU to PL Inter Process Interrupt
Hi @monica_4780
Currently we do not have variation for the feature you requested.
Please use below example for sefltest where same IPI channel can trigger and receive the interrupt.
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/ipipsu/examples/xipipsu_self_test_example.c
You need to trigger the interrupt from IPI PL channel x
Best Regards
Kranthi
Hi Kranthi,
Thanks for your reply. An implementation at least with MicroBlaze softcore processor would be quite helpful. That is an example for Interprocess Interrupt between MicroBlaze and Cortex-A53 using PL IPI.
