Visitor holder
ARM A53 CPU clock speed for ZCU102
I am using the ZCU102 evaluation board (device XCZU9EG).
I see in document ds925 table 3 shows different possible speed grades.
Is there a way to determine from u-boot what the ARM A53 clock speed is?
thx,
bob
Here is the boot console output:
Xilinx Zynq MP First Stage Boot Loader
Release 2017.4   Dec 14 2017  -  10:48:32
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):47af34b
NOTICE:  BL31: Built : 17:54:34, Dec 14 2017
U-Boot 2017.01 (Dec 14 2017 - 10:48:04 -0700) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        xczu9eg
MMC:   sdhci@ff170000: 0 (SD)
zynqmp_qspi_ofdata_to_platdata: CLK 124987500
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in SROM is         ff:ff:ff:ff:ff:ff
Address in environment is  00:0a:35:03:77:e7
eth0: ethernet@ff0e0000
Hit any key to stop autoboot:  0
Re: ARM A53 CPU clock speed for ZCU102
Hello @holder,
The clock speed of the ARM A53 should be set in the PS when you setup your Vivado project.  The table in DS925 refers to the physical specification of different parts.  On DS891 (https://www.xilinx.com/support/documentation/data_sheets/ds891-zynq-ultrascale-plus-overview.pdf) page 40, there is a table which references which speed grade the ZU9EG is at (I am assuming your device is an Extended part so has speed grade -1E).
To your question about seeing the clock speed in u-boot from your PS configuration, I am unsure what the application would be that would require that functionality.  Could you elaborate on what this would be used for?
If you need to see the clock speed, but can wait until Linux is booted up, this AR (https://www.xilinx.com/support/answers/51190.html) should help.
Caleb Davidson
Caleb
Hello @holder,
Caleb Davidson
Caleb
In Linux can can read CPU0 frequency by
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
if you wan to do cpu freq scaling, please refer to the wiki page
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841831/CPU+frequency+scaling
