Visitor ctelfer
AXI DMA Cyclic Mode Interrupts
Will any interrupts be generated with the AXI DMA in cyclic mode?  I understand the Completed bit will be ignored in this mode, so how then is the IOC interrupt affected?  Is the interrupt still raised?  If no, is there any other option for having the AXI DMA interrupt while in cyclic mode to signal memory  transfer progress?
Thanks!
Re: AXI DMA Cyclic Mode Interrupts
Hi @ctelfer,
The IOC interrupt is generated in cyclic mode. It's operation does not differ from non-cyclic Scatter Gather mode.
Deanna
Hi @ctelfer,
Deanna
