AXI DMA data transfer Error (Simple transfer mode)
I have a counter which dumps data into a fifo of width 1024 and counter length 512.
I want to trasfer data from Fifo to PS using AXI DMA.
My DMA is configured for simple mode transfer..
- width of Buffer length Register =14
-Max Burst size = 128
-Allow Unalinged Transfer [Enabled]
-all others are left as default.
-only wright channel is enabled
-address with 32 bits
this is the program i am using
#define MEM_DDR_ADDR 0x01000000
#define C_BASE_ADDR 0x40400000
#define S2MM_DMACR C_BASE_ADDR + 0x30
// S2MM_DMASR S2MM DMA Status register
#define S2MM_DMASR C_BASE_ADDR + 0x34
// S2MM Destination Address. Lower 32 bit address.
#define S2MM_DA C_BASE_ADDR +0x48
// S2MM Destination Address. Upper 32 bit address.
#define S2MM_DA_MSB C_BASE_ADDR + 0x4c
// S2MM Buffer Length (Bytes)
#define S2MM_LENGTH C_BASE_ADDR + 0x58
#define INTR_ID XPAR_FABRIC_AXI_DMA_0_S2MM_INTROUT_INTR
void resetDMA(void)
    Xil_Out32(S2MM_DMACR, 0x00000004);
uint32_t getIOCIRQU(void)
    return Xil_In32(S2MM_DMASR) & 0x5000;
void clearIOCIRQU(void)
    uint32_t value = Xil_In32(S2MM_DMASR);
    value |= 0x5000;
    Xil_Out32(S2MM_DMASR, value);
void setIOCIRQU(void)
    uint32_t value = Xil_In32(S2MM_DMACR);
    value |= 0x00007000;
    Xil_Out32(S2MM_DMACR, value);
void startDMA(void)
    uint32_t reg = Xil_In32(S2MM_DMACR);
    reg |= 0x00000001;
    Xil_Out32(S2MM_DMACR, reg);
void stopDMA(void)
    reg &= 0xfffffffe;
uint32_t hasSG(void)
    return Xil_In32(S2MM_DMASR) & 0x00000008;
uint32_t getS2MMLAddr(void)
    return Xil_In32(S2MM_DA);
uint32_t getS2MMHAddr(void)
    return Xil_In32(S2MM_DA_MSB);
void setS2MMLAddr(uint32_t value)
    Xil_Out32(S2MM_DA, value & 0xffffffff);
void setS2MMHAddr(uint32_t value)
    return Xil_Out32(S2MM_DA_MSB, value & 0xffffffff);
uint32_t getS2MMLenght(void)
    return Xil_In32(S2MM_LENGTH);
void setS2MMLenght(uint32_t value)
    Xil_Out32(S2MM_LENGTH, value & 0x1ffffff);
int main()
    uint32_t s2mmLAddr = 0;
    uint32_t s2mmHAddr = 0;
    uint32_t s2mmLenght = 0;
    uint8_t sgIncluded = 0;
    init_platform();
    for(uint32_t i = 0; i < 100; i++)
        printf("\r\n");
    sgIncluded = hasSG();
    printf("********* In [ %s ] *********\r\n", __FUNCTION__);
    printf("SG %s included\r\n", (sgIncluded) ? "is":"is not");
    s2mmLAddr = getS2MMLAddr();
    s2mmHAddr = getS2MMHAddr();
    s2mmLenght = getS2MMLenght();
    startDMA();
    setIOCIRQU();
    printf("DMA Control Register = 0x%.8lx\r\n", Xil_In32(S2MM_DMACR));
    setS2MMLAddr(MEM_DDR_ADDR);
    setS2MMHAddr(0x3fffffff);
    setS2MMLenght(0x000001ff);
    printf("Register length = 0x%.8lx\r\n", s2mmLenght);
    printf("Low Address = 0x%.8lx\r\n", s2mmLAddr);
    printf("High Address = 0x%.8lx\r\n", s2mmHAddr);
    while(1)
        uint32_t *datap = (uint32_t *) s2mmLAddr;
        while (!getIOCIRQU())
        clearIOCIRQU();
        for(uint8_t i = 0; i < 8; i++)
            printf("@%.8lx => data[%02d] = 0x%.8lx\r\n", datap, i, *datap);
            datap++;
    printf("********* Out [ %s ] *********\r\n", __FUNCTION__);
    cleanup_platform();
    return 0;
It runs for sometime if i write the length of tranfer 0x100 or higher . and gives error;
S2MM_DMASR value = 0x5011
and when i want to trasfer data again after first block it does'nt work and S2MM_DMASR value = 0x0011
Also it doesn't transfers data of lesser size say 10 or 20 bytes.
How can i configure the DMA to transfer the data of whatever size i want .
Is there any example i can refer?
i also want to capture the completion interrrupt and transfer data accordingly ,please help
Tags (3)
