AXI DMA in SG : Interrupt generated before given number of BDs are processed?
Hi people,
We have our custom module that sends data to Axi DMA which works in SG mode. Through software we set DMA to generate interrupt after N number of packets are transferred (we do that with Coalescing counter) from our module to DDR. So, number of BDs we want to transfer is N * BDS_PER_PKT = X. It happens that DMA generates interrupt but when we get number of processed BDs from hardware (with XAxiDma_BdRingFromHw function) that number is often X-1, or X-2, sometimes even X-3 or X-4. So, number of BDs processed and transferred by DMA is smaller than number we defined. Confusing thing is that DMA generates interrupt regardless of that, as though right number of BDs are processed. More confusing thing is that when we check what is written to memory sometimes everything is transferred as expected, but more often we miss that size ((X-1)*MAX_PKT_LEN, (X-2)*MAX_PKT_LEN, etc...) of data in memory.
Where could be a problem, any hint?
Re: AXI DMA in SG : Interrupt generated before given number of BDs are processed?
Thanks for answer, but it seems that we solved the problem in the meantime. And the problem was, of course, our module, which had some kind of latency when generating signals tlast and tvalid.
Below forum thread are having related discussions with respect to your query. Please check whether they are useful for you
https://forums.xilinx.com/t5/Embedded-Development-Tools/Axi-DMA-in-SG-multi-channel-mode/td-p/558997
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/how-to-get-peak-throughput-for-AXI-DMA/td-p/667827
