AXI DMA to On-Chip Memory
I have a working design that transfer data from PL to DDR Memroy via AXI DMA but does not work with OCM.  Is there anybody knows DMA to OCM doable?
Henry
Tags (2)
Re: AXI DMA to On-Chip Memory
More fundamentally what is happening is that a Decode Error response is received over the AXI interface. Yes, this means an address decode error at an interconnect somewhere. Some possible causes might be that the OCM address range is not mapped to that DMA interface port in the address tab, or that there is a trustzone violation (if the DMA is doing a non-secure access, but OCM is a secure slave by default).
Yes, OCM should look just like the PS DDR. Perhaps you have a cache coherency issue?
Hi Dylan,
Thanks for your reply.  I tested the AXI DMA to OCM on some other platform and confirm that it is doable.  For the problem on our own platform, in the stream to memory map status register S2MM_DMASR, the DMA Decode Error bit, DMADecErr, was asserted.  According to the user guide, the Descriptor Buffer Address points to an invalid address.
Henry
You are right Dylan.  I blew away the interconnect and reconnect the AXI DMA.  Now I found the dma mapped to the OCM correctly.  Then, I run the firmware and it does not stuck by any error.
Thanks very much.
Henry
