AXI DataMover control interface
Hello guys,
In my design, I'm using AXI DataMover v5.1 IP core (PG022 from April 2017) to convert data from AXI4-Stream to AXI4-Memory Mapped format (S2MM). Consequently, I'm using S2MM part only of AXI DataMover IP core.
My goal is to alternatively store AXI4-Stream data in two different areas of BRAM memory. For that reason, through AXI4-Stream control interface (m_axis_s2mm_cmd_*) I continuously send the following commands:
m_axis_s2mm_cmd_tdata <= {4'b0, 4'b0, 32'h0, 1'b0, 1'b0, 6'b0, 1'b1, 23'h14};
// RSVD, TAG,  SADDR, DRR,  EOF,  DSA,  Type, BT
and
m_axis_s2mm_cmd_tdata <= {4'b0, 4'b0, 32'h400, 1'b0, 1'b0, 6'b0, 1'b1, 23'h14};
// RSVD, TAG,  SADDR, DRR,  EOF,  DSA, Type, BTT
With those commands, I try to specify the amount of data I want to send (e.g. 23'h14 in above commands) as well as the destination in BRAM memory area (e.g. 32'h0 and 32'h400 in above commands).
Control commands are sent one after another, continuously. As soon as s_axis_s2mm_cmd_tready signal allows me to pass the next command, I pass it. At the same time, I have AXI4-Stream data connected with s_axis_s2mm_* interface sending data in packets of 23'14 (20) Bytes
Should I wait for some kind of flag/confirmation from AXI DataMover IP before I send next AXI4-Stream command or it is OK to send the command I do? The approach I use seems to work on the simulation level.
Thanks in advance for your time and effort.
Sincerely,
Bojan.
Scholar jg_bds
Re: AXI DataMover control interface
I notice that you're not providing CACHE and USER fields in your command.  The USER field is (probably) not important, but the CACHE might be: assuming the tool presumes a CACHE value of 4'h0, that translates to a MEMTYPE of "Non-bufferable".  That's not a type that's best used in a high-throughput pipeline. If possible, I'd use "Bufferable" (4'h1).
Otherwise, your interface seems fine. The DM IP will assert back-pressure by de-asserting the TREADY signal until it's able to accommodate another command word. It's better to make sure the command word is available even when it's not needed, rather than have it unavailable when it's needed.
The only downside is losing track of the number of outstanding commands that were issued, when you want to change things around. That's, of course, nothing a good reset couldn't fix. (So make sure you can properly reset the DM IP.)
-Joe G.
Scholar jg_bds
-Joe G.
Hello @jg_bds,
Thanks for your feedback. Concerning CACHE and USER fields in my command, I don't have them because I did not check Enable xCACHE xUSER  during customization of DM IP core. I did not check that field because I was not aware of CACHE and USER meaning. PG022 does not explain in details the meaning of those two fields .
I need DM IP for high-throughput pipeline so I'm interested in optimizing the things. Is your suggestion to check Enable xCACHE xUSER field, set 4'h0 for xUSER and 4'h1 for xCACHE ?
Where can I read more about the meaning of xCACHE xUSER fields?
Thanks once again for your great support.
Sincerely,
Bojan.
Scholar jg_bds
You likely can continue to ignore the USER signals, if they're not mentioned in the IP user guide.
The CACHE signals are covered in moderate detail in the AXI-4 Protocol spec.
-Joe G.
OK, thank you very much, @jg_bds
Scholar jg_bds
My bad... I updated my B.C (before coffee) reply. We're not talking AXI stream on that side of the AXI DM IP.
