AXI Master transaction
Hello Everybody here! I Please answer me for the question. Is it  possible to create transaction between AXI Master interface to User IP through the AXI Interconnection?
Scholar hbucher
Re: AXI Master transaction
@marzhan_123 @a_chami
Perhaps he is talking about calling custom code from an AXI design.
Yes, you can package your IP inside an AXI component. It is pretty easy to do. See XAPP1168
https://www.xilinx.com/support/documentation/application_notes/xapp1168-axi-ip-integrator.pdf
Yes, it is possible. Maybe if you give more details about your configuration we can help regarding your question, or problem, if you have one.
Avi Chami MSc
FPGA Site
Scholar hbucher
Teacher muzaffer
@marzhan_123  your question is not clear to me. The pieces in an axi transaction are the master, interconnect and (one or more) slave(s). If you implement your user IP as an axi slave, you can connect it to a master port directly or through an interconnect and have the master generate transactions for the slave. How this is accomplished depends on your master design. Sometimes the master is connected to a processor so you execute code on the processor to access your slave. Sometimes the master is a dma controller so you program the dma controller to generate the axi transaction. Sometimes you have a custom axi master where you add the RTL logic to your master to generate the transactions.
