Voyager
Voyager
AXI Quad SPI clock configuration
I'm using that IP block with Artix-7 to write data to an SPI flash, I'm having spurious random errors. I tried lowering the clock frequency tying the ext_spi_clk pin to an 8 MHz clock to have in theory 4 MHz SPI clock but I'm suspecting it's not working as it takes the same time as with 30 MHz.
Do I have to do anything else to change the SPI clock?
By the way, if that matters, is the configuration SPI and there is a clock constraint in the configuration file. I wonder if it's possible to have the configuration loaded with the clock specified in the bitstream, then using the SPI with another clock.
