AXI Stream FIFO RDFO Register always zero
I have been trying to implement a fifo to offload data from the fabric into the MicroBlaze. I am using the VC707 bev board, and Vivado 2014.2. I have a counter that is generating data and driving the AXI stream fifo. A general block diagram of the system can be seen in the attached JPG. I started with the Xilinx Interrupt FIFO Example c code. I modifed the example code to only read from the FIFO because the data is coming from my counter on the FPGA. I added some printf statements and if I run the code I get the following output:
--- Entering main() ---
Receiving Data...
Errors: 0
ReceiveLength = 3
RDFO Register = 0x0
Receiving Data...
Errors: 0
ReceiveLength = 3
RDFO Register = 0x0
The c code is attached.
The FIFO understands that it has three words of data in the fifo, but the RDFO is always zero. I am setting the tlast flag (as seen in the attached debug figure) on the thrid piece of data.
I changed the size of the data in the fifo_intr.c file to show three packets:
#define WORD_SIZE 4            /* Size of words in bytes */
#define MAX_PACKET_LEN 3
#define NO_OF_PACKETS 1
#define MAX_DATA_BUFFER_SIZE NO_OF_PACKETS*MAX_PACKET_LEN
Does anyone know why RDFO is always zero?
