Observer shhrikant1
AXI bridge for pci express Gen3 axi_ctl_aclk connection
The user guide says that axi_ctl_aclk input should be driven by axi_aclk output.
Does that mean the axi_aclk output of the bridge itself ?
what is the significance of such a feedback system.
World is great with FPGAs
Re: AXI bridge for pci express Gen3 axi_ctl_aclk connection
The axi_aclk and axi_ctl_aclk ports should be connected to the axi_aclk_out and axi_ctl_aclk_out clocks, respectively. This will prevent any transferring of clock domains within the core.
check the similar post here
https://forums.xilinx.com/t5/PCI-Express/AXI-Bridge-for-PCI-Express-Gen3-Subsystem-sys-clk-gt-use/td-p/552565
http://www.xilinx.com/support/documentation/ip_documentation/axi_pcie3/v1_0/pg194-axi-bridge-pcie-gen3.pdf
check this ARs as well
http://www.xilinx.com/support/answers/43706.html
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
