AXI clock converter
I am using AXI clock converter IP core and have some questions:
1) Is this IP core documented somewhere? I Couldn't find anything.
2) Difference with the other AXI4 clock converter.
3) Can one programatically (from PS for example) control the clock converter frequency, i.e. change dynamically the frequency of AXI streams.
Thanks for any tips
Re: AXI clock converter
Hi @ziladdev
This is an AXI Infrastructure core that is detailed in the AXI Interconnect product guide (PG059) which can be found in Doc Nav. If you right click on the AXI Clock Converter IP in IP Catalog in Vivado and select Product Guide it will direct you to the IP product guide.
Kind regards,
Gareth
Voyager
Voyager
The Clocking Wizard is IP that you are looking for:
https://www.xilinx.com/support/documentation/ip_documentation/clk_wiz/v6_0/pg065-clk-wiz.pdf
It supports dynamic reconfiguration via an optional AXI-Lite interface.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
I am well aware of the clocking wizard, it is not the IP I am referring to. AXI Clock converter is an IP that changes the speed of the AXI bus.
Hi @ziladdev
Kind regards,
Gareth
Oh that's where it's been hiding. I saw the documentation pointing out to that and I thought it was a mistake as the document name was misleading. Thanks for the info!
Please see pg059-axi-interconnect.pdf,
and search keyword: 'axi clock converter'.
