AXI ethernet scatter-gather mode interrupt example
I am using the attached hardware design (AXI ethernet with DMA in sg mode) and I am using the xaxiethernet_example_intr_sgdma_1 (example provided in SDK for AXI ethernet).
However, the example does not run and throws the error: “Error committing the RxBD to HW”(XAxiDma)BdRingToHw function). I searched the forum to check if there are any threads related to it but so far I just found one thread which stated that I should keep the DMA in scatter-gather mode and allow unaligned transfer and both are enabled in my design.
I understand that this has to do with the AXI DMA, however, I am unable to figure out the exact cause. Could someone let me know if there are any changes that should be made to run this example. I am using this ethernet fmc:http://ethernetfmc.com/
Re: AXI ethernet scatter-gather mode interrupt example
Finally, I found the fix here: https://github.com/Xilinx/embeddedsw/commit/c6769786f21c734671b752a2d0ed4fb82c4d68b8#diff-044069a623322337a67daf0445a4a8d8
Add this line: XAxiDma_BdSetLength(Bd1Ptr, XAE_MAX_JUMBO_FRAME_SIZE,
RxRingPtr->MaxTransferLen);
and remove this: XAxiDma_BdSetLength(Bd1Ptr, sizeof(RxFrame), from the #else part!
Hope it'll help.
Hi @bbhatt,
Could you try with below AXI DMA settings?
Praveen
Thank you for the reply. I have same settings as mentioned, is there anything else that I could try? I ran an example on AXI DMA with FIFO (loopback) and it worked as expected, not sure what am I not doing correctly here.
Hope it'll help.
