AXI4 4K address boundary
Hi, guys, According to the ARM amba_axi_protocol document, a burst must not cross a 4KB addresss boundary. When I use vivado to create my own IP with AXI4 interface, the automatically generated design file xxxxxx_M0_AXI.v shows "Non-2^n lengths will eventually cause bursts across 4k address boundary" (in the comment for local parameter C_MASTER_LENGTH). So my question is does that mean non-2^n burst length is not allowed for the AXI4 protocol? Thanks
Re: AXI4 4K address boundary
@joker0208,
Not at all.  _AXI_AxLEN values can be anything from 0 (burst length 1) through 255 (burst length 256).  Nothing prevents you from abusing the protocol and crossing 4kB boundaries in your master.
If I understand correctly, this limitation is designed to keep you from crossing peripherals within a single burst.  If every peripheral's base address is on a 4kB boundary, and the protocol doesn't allow you to cross a 4kB boundary within a burst, then any and all bursts will only ever reference a single peripheral.  Crossing peripheral boundaries inside a single burst can make things difficult for the interconnect to deal with.  (i.e., what happens when one peripheral returns values before another, etc.)
Dan
@joker0208,
Dan
Thank you, Dan. It makes sense.
