Visitor tuxtech
AXI4-Stream FIFO receive data from custom VHDL peripheral
i'm designing a system on a ZYNQ where a custom VHDL module sends data to an AXI4-Stream FIFO, which is connected via AXI4-Lite to a MicroBlaze:
VHDL-Module -----AXI4-Stream----AXI4-Stream FIFO-----AXI4-Lite-----MicroBlaze
I used the xllfifo_polling_example.c and successfuly sent data from the MicroBlaze to the Module by just shorting TREADY and TVALID of the FIFO block. Now I'm trying to let the MicroBlaze receive data. I set TVALID always to 1, waited for TREADY to become 1 and then assigned my 32-bit data to TDATA. When I run the MicroBlaze FIFO exampe, i get the folowing UART output:
--- Entering main() ---
 ERROR : Reset value of ISR0 : 0x4000000        Expected : 0x0
Axi Streaming FIFO Polling Example Test Failed
--- Exiting main() ---
The ISR-REgister is cleared before and then read again and bit 26 is set. which means "Receive Complete / Interrupt pending".
Why does that error occur?
Is my approach correct or should i use the IP-Packager and create a new custom AXI4-Stream peripheral?
Thanks for your help.
Visitor liudi
Re: AXI4-Stream FIFO receive data from custom VHDL peripheral
i want to send data from pc to fpga using ethernet communation,now i have created the block design with microblaze,and completed the ethernet communation and received the data,but i need to store the received data to DDR3,and i also need write the data from  DDR3 to a FIFO,but I don't know which kind of FIFO I need to add to the .bd and write C code in SDK to control the FIFO,is there any FIFO API I can use to realize my project.
Additionally, dose the code xllfifo_polling_example.c have any reference value for me ?
