AXI4-Stream Infrastructure IPs' aclken polarity is showing wrong ?
I believe the polarity of the aclken input for all of the infrastructure cores is active high. However, this is not really mentioned anywhere in PG085 (however it is mentioned in UG761) and it is wrongly shown as active low when cores are instantiated in a block diagram. Please clarify.
/Mikhail
Re: AXI4-Stream Infrastructure IPs' aclken polarity is showing wrong ?
Hi @mmatusov,
Yes, the aclken input for the AXI4-Stream Infrastructure cores is an active high signal.
It looks like IPI automatically inserts the a bubble on the aclken pin of the AXI4-Stream IP. This would typically indicate an active low signal and is an error. There are a couple of bugs open about this. We are targeting a fix in 2019.1.
Deanna
Hi @mmatusov,
Deanna
Hi @demarco,
Just to be clear, it's not only a bubble, the POLARITY pin property is set to ACTIVE_LOW as well.
/Mikhail
Hi @mmatusov,
I missed that aspect in my initial response. Yes, that has been identified as a key part of resolving the issue.  The POLARITY property should be ACTIVE_HIGH, not the ACTIVE_LOW you are observing.
Deanna
