Newbie stsl
AXI4-Stream Interconnect v2.1 - S_AXI_CTRL
I would like to use the S_AXI_CTRL port on the "AXI4-Stream Interconnect v2.1" IP, but I couldn't find any documentation on it. I only found the documentation for v1.1 of the IP which did not have that S_AXI_CTRL interface option. I'm using Vivado 2015.4.
Thanks for the help!
Re: AXI4-Stream Interconnect v2.1 - S_AXI_CTRL
Hi @stsl,
To find the correct documentation for an IP, right click on the IP in the IP catalog and click on "Product Guide". This should redirect you to the correct product guide in DocNav:
In your case you are looking for the PG085:
http://www.xilinx.com/support/documentation/ip_documentation/axis_infrastructure_ip_suite/v1_1/pg085-axi4stream-infrastructure.pdf
This will contains the information you are looking for:
Florent
Florent
Hi @stsl,
Florent
Florent
Observer yida123
Hello! I find the documents,but i couldn't find something about the S_AXI_CTRL port,what can i do?
HI @yida123,
What can you do....
  1. Re-read the document... The screenshot is exactly showing the S_AXI_CTRL port, which mean there is something in the documents...
  2. Create a new topic explaining better in which context you are looking for this
Florent
Observer yida123
Thanks for your reply. I couldn't create a new topic(always meet the html error). I read the guide documents,but it don't mention about how to create the Ctrl port,when I use the IP,it just has the port S_AXIS with no port named S_AXI_CTRL.
