About AXI lite slv_reg for custom ip purpose
I'm traying to learn zynq soc for a while. When I generete a custom axi lite (default setting), vivado gives me 4 slv_reg(slv_reg0islv_reg1,slv_reg2,slv_reg3). However I need 8 of them. Can I manually add svl_reg to the hdl file (slv_reg4, slv_reg5,....) or how to do that?
 (default setting),
Thank you.
回复: About AXI lite slv_reg for custom ip purpose
Hi @fpgatr ,
Change the number of Registers from 4 to 8.
You will find slv_reg4-7 in hdl file.
It is not suggested to manually add another 4 slv_reg.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Hi @fpgatr ,
Scholar dgisselq
Re: About AXI lite slv_reg for custom ip purpose
@fpgatr,
Don't forget to "fix" the generated code before using it!  Xilinx's demo AXI and AXI-lite examples both have bugs in them that might cause your design to freeze up when you aren't expecting it.
Dan
