About Reset pin in PS DDR dedicated pins
Hi. In PS DDR controller pins I have one called "PS_DDR_DRST_B". So I look for the corresponding pin on my memory chip device. The problem is that my chip doen't hace such pin. This memory is DDR2 and the part number is MT47H64M8CF-25E IT . Is importan to me to know if this situation is normal in DDR2 chips and where I have to connect this pin in case. Pull up to VCCO_DDR? If someone can clarify me about this...
Santi
Re: About Reset pin in PS DDR dedicated pins
DDR2 do not have reset pin for the chip so you can leave it unconnected.
Please refer Table named "DDR unused Pins" of UG933 for more details
http://www.xilinx.com/support/documentation/user_guides/ug933-Zynq-7000-PCB.pdf
Hope this helps
Vanitha
Hope this helps
Vanitha
Thanks, it helps.
