Accessing SD card from XCKU040 in the KCU105 Board
I am trying to implement basic read and write to the SD card(Without any file system) through the FPGA. I have chosen SPI mode which I found simpler. I am using the SD card slot present in the KCU105 board.The SD card that I am using is Samsung EVO plus(SDHC).  I have tried two approaches for this.
1) Implemented Microblaze with AXI-Quad SPI and wrote C program.
2) Directly implemented FSM in RTL.
In both of the cases I have waited more than 74 cycles keeping DI and CS high, Made CS low and Sent the CMD0 (40 00 00 00 00 95). I am expecting the DO line to go low but it stays high. I haven't tried past initialisation since I haven't got any response. I have verified that SD card slot and SD card are functional by configuring the FPGA from SD card through UART menu that the board presents.
Am I doing something wrong or is the SD card accessible to only on-board zync system controller? I have seen in the schematics that there are Muxes between SD card to Zync and xcku040.  Please note that this question is NOT ABOUT CONFIGURING FPGA FROM SD CARD,for which I found plenty of resources. I just want to access it to store data. It would be really helpful if there are any examples.
Re: Accessing SD card from XCKU040 in the KCU105 Board
@pramodjb2808 Use xilffs. Pins are exposed as MIO.
You have a perfect example if you create a FSBL for a standalone hello world project for example.
Hello Henrique. Aren't MIO and EMIOs relevant only to Zync? Because I thought you are free to use any IO on Ultrascale FPGA since they aren't multiplexed with peripherals. (Ignoring that sd slot is connected physically to specific pins on board).
I will try xilff lib.
Thanks for your time!
@pramodjb2808 Yes, you are correct. My mistake.
