An echo server designed with lwip. Help needed
Hi guys:
    I have designed an echo server with lwip3.0 in EDK9.2. The lwip works in socket mode. I use the sp3e500e (the starter kit board).
    Now I want to make my PC work as a client to verify the design. My problem is that how could I program the client on PC? If someone could give me an validated design, I will sincerely appreciate it.
Here is my design of server:
// Located in: microblaze_0/include/xparameters.h
#include "xparameters.h"
#include "xmk.h"
#include "stdio.h"
#include "lwip/sockets.h"
#include "lwipopts.h"
#include "lwip/inet.h"
#include "netif/xadapter.h"
#include "lwip/sys.h"
void* processConnection(void* arg){
 char revbuf[RECV_BUFFER_SIZE];
 int bytereceived;
 int sd=*((int*) arg);
 char sendbuf[1024]="send data from FPGA";
 lwip_write(sd,sendbuf,1024);
 bytereceived=lwip_read(sd,revbuf,RECV_BUFFER_SIZE);
 xil_printf("received data length is %d\r\n",bytereceived);
 xil_printf("received data is %s\r\n",revbuf);
void* serverAppThread(void){
 struct netif* pnetif;
 struct netif servernetif;
 struct ip_addr ipaddr, netmask, gw;
 struct sockaddr_in address, remote;
 int sock;
 int new_sd;
 int size;
      unsigned char mac_ethernet_address[] = { 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
    IP4_ADDR(&ipaddr, 192, 168, 1, 224);
    IP4_ADDR(&netmask, 255, 255, 255, 0);
    IP4_ADDR(&gw, 192, 168, 1, 1);
     pnetif=&servernetif;
    if (!xemac_add(pnetif, &ipaddr, &netmask, &gw, mac_ethernet_address, ETHERNET_MAC_ADDRESS))
        xil_printf("Error adding N/W interface\n\r");
        return;
    netif_set_default(pnetif);
     netif_set_up(pnetif);
      sys_thread_new((void(*)(void*))xemacif_input_thread, pnetif, 1);
    sock = lwip_socket(AF_INET, SOCK_STREAM, 0);
    address.sin_family      = AF_INET;
    address.sin_port        = htons(8080);
    address.sin_addr.s_addr = INADDR_ANY;
    lwip_bind(sock, (struct sockaddr*)&address, sizeof(address));
    xil_printf("Server initialization complete.\r\n");
    lwip_listen(sock,4);
    size=sizeof(remote);
    new_sd = lwip_accept(sock, (struct sockaddr *)&remote, &size);
    xil_printf("accepted from socket %d\r\n",new_sd);
    sys_thread_new((void *)&processConnection, &new_sd, 1);
void* serverThread(void){
     lwip_init();
    sleep(300);
    sys_thread_new((void *)&serverAppThread, 0, 1);
int main (void) {
   xillkernel_main();    //The serverThread() gets executed;
   return 0;
Visitor tsemer
Re: An echo server designed with lwip. Help needed
you may use hyperTerminal if you work under windows or any other terminal application on linux  and ping on your server.
good luck
