Any Chipscope tutorial to debug FPGA logic in Zynq
Hello Guys,
I have found many chipscope tutorials .But, I only want to debug the FPGA logic in zynq is it possible?
Do we have any tutorial in this case.
Kind Regards
Pruthvi
Observer uetze
Re: Any Chipscope tutorial to debug FPGA logic in Zynq
This is exactly the same as with other FPGA families.
greetings
Hannes
Hello Hannes,
Thanks for your reply.
I have already started working on this.
I have an error while implementation saying :"save failed due to mkdir failure "
I have searched in google and found its a problem with write protected project files.
I have tried to change the properties of many project files but dont know exactly which project files, properties need to be changed
Can you tell me which files need to be changed
Pruthvi
Observer uetze
Hello Prutvhi,
have you seen this? http://www.xilinx.com/support/answers/36547.htm
It sounds more rights at the operating system level. In Windows, once do not try to take the path C :/ Users / * myUser * / Documents / .... Instead create a Folder with full access for everyone. And no spaces in the path.
greeting
Hannes
This PDF has a Zynq specific ChipScope demo.  Setup is in Chapter 3, Debugging explanation is in Chapter 4.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/ug873-zynq-ctt.pdf
