Observer tobis
Assigned Address of IP core not propagated to xparameters.h
Hey guys,
I have a custom ip with an correctly assigned AXI Slave address in the address editor (0x80010000). After exporting the hardware to xsdk the address is also corretly showing up in the system.hdf file. But the xparameters.h file is showing the wrong address 0x00000000.
(info: In my custom IP is another IP core which uses this AXI Slave interface)
Vivado/ XSK version: 2017.4
What can i do to solve this issue?
Thank you
Re: Assigned Address of IP core not propagated to xparameters.h
The driver used by the BSP is responsible for populating the core's address in xparameters.
If you have a custom driver for the IP, make sure the driver's tcl contains something like:
proc generate {drv_handle} {
    xdefine_include_file $drv_handle "xparameters.h" "my_regmap" "NUM_INSTANCES" "DEVICE_ID"  "C_S00_AXI_BASEADDR" "C_S00_AXI_HIGHADDR"
If you are not using a custom driver, make sure that the BSP driver for your IP core is set to 'generic' instead of 'none'. The generic driver will populate addresses in xparameters
Observer tobis
No one has a solution? Please help.
