Visitor zpeezer44
Attempting to Program Nexys Video SPI Flash With Microblaze C Code
I have been following this tutorial and have had no luck. I am uncertain about how to configure the QSPI IP, because the tutorial starts assuming that I have done that part successfully, so I am not even sure if this is the root of my problem. I have tried these two configurations of this IP, compiled them, and exported them to the SDK, and none of them solved the problem:
I made sure JP4 is in the QSPI position. On step 3.1 in the tutorial, I can see that the FPGA is programmed successfully and I see the following output (since I chose not comment out the VERBOSE define as suggested in the tutorial):
While programming the flash on step 4 I notice that my FPGA code is erased from the board (leds I had assigned to outputs turn off). Is that supposed to happen?
At the end of the tutorial I get no "hello world" output on the terminal after resetting the board, though the FPGA does seem to program from the flash successfully, so that portion works, but I can't get the C-code to run from the flash.
Here is the sdk_console_output.txt so you can see the steps I took in the sdk to program the board.
Tags (4)
Re: Attempting to Program Nexys Video SPI Flash With Microblaze C Code
If you are using Vivado 2018.3, try using 2018.2.2.  It appears something is broken in QSPI flash programming in 2018.3.   I cannot get it to work for me, either, but it works fine in 2018.2.2.
See my post here:  https://forums.xilinx.com/t5/Configuration/SPI-bootloader-broken-in-2018-3/td-p/928739
