Participant dpandya9488
Re: BRAM Acces to write it from PL and read from PS and compute that data
One more confusion I have regarding BRAM read and write / access operation on linux based platform..
I have done the DDR access from PS using "mmap" function call and using "/dev/mem/" access on linux platform.. But when I will need linux platform based BRAM access will this library "xil_io.h" will be valid method for this or any other way to access BRAM on linux platform.
Dhara
Advisor ronnywebers
Advisor
@dpandya9488, I'm not a linux sofware expert, but I googled 'zynq access bram from linux user space', and it gives me this wiki page, think that contains all you need.
I have done something similar to you. Can u plz chk it what is the issue in my design or SDK code ?
In SDK, if i write j=j+1,i get only one value.
I am sending data from PL which is  increamented by 1 but not getting the same data when i read it from PS. Instead i am getting values as 00,04,08,0C......
I should get 00,01,02,03,04,05,06......Am i right ?
What is the problem ?
sir can give me the pl code,for that fsm which u mentioned,i have nobody to guide me at my current place,as iam still learning,but this is a part of my project which i should submit,please attach me this pl code,as i can learn how to infer it..please sir send it as soon as possible
sir please help me as i need that fsm code,as iam a novice in my company..and i have nobody to guide me here please..help me sir
can you give me this good mate..i have nobody to guide me and this is part of my project
thanks in advance
sir can u give me fsm code
sir help
which code do u want ?
i have an axi BRAM controller,connected to Dual port BRAM...port a of dual port bram writes data from PS,and port B Reads data from PL,
FSM that reads the data on each address, adds 1 to it, and writes it back. to Read from pl..please help..i can description of code
I just made a custom ip, package it and then include it in the Block Diagram. I am reading from Port A of BRAM from PS side and writing from Port B of BRAM.
Basically on the rising edge of the clock I am updating the data and address by addition of four as shown below. The data and address signals are initialized by 32 bit zeros, please see the source code in attachment.
dinb_s <= dinb_s + conv_std_logic_vector(4, 32);
addrb_s <= addrb_s + conv_std_logic_vector(4, 32);
The output (when reading using 8 bit function in SDK) on the serial should be
Base address + 00 : 00
Base address + 01 : 00
Base address + 02 : 00
Base address + 03 : 00
Base address + 04 : 04
Base address + 05 : 00
Base address + 06 : 00
Base address + 07 : 00
Base address + 08 : 08
-..design is something like this
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/BRAM-Acces-to-write-it-from-PL-and-read-from-PS-and-compute-that/td-p/830210
niranjan in this forum..the discussion has been done and solution has been recieved..but the references have been deleted..please let me know on the solution in depth
sir i need this fsm with axi_gpio
Advisor ronnywebers
Advisor
@sam007, I don't have the time at the moment to write you a FSM, but in the past I did put a good FSM example on the forum, after getting great input from other people.
The FSM uses a 'single process' approach (vs. the classical 2 or 3 process aproach found in books), which makes it very simple to read and understand. This 'single process' approach is also shown in UG901 (Synthesis, chapter 4, HDL coding techniques). Please checkthe code in this answer of the threadt, it should get you going with FSM's. Also read the entire thread from the start, so you can understand it better, there's some great explanation by other forum users on my questions.
help
thanks for the reply,but can u explain me the logic,but iam comfortable in verilog...can you suggest me that and can u explain me the logic quoted by you,
"you could for example build an FSM that reads the data on each address, adds 1 to it, and writes it back. Then you'll also need something to trigger a 'start' of this caluclation, and optinally signal an end. A small example will help...
thanks in advance
give code mate
Advisor ronnywebers
Advisor
@sam007, I don't have any code ready at this moment, especially not Verilog as I use VHDL
Did you try to write to the BRAM from the PS and read back from the PS first? Just to see that the PS code is working fine.
Also can you share a screenshot of your entire block diagram here and your entire verilog file? (please use the 'insert code' function for this, it's the </> icon above this editor.
Did you add an 'ILA' on the interfaces to see what's happening?
HERE I WAS GETTING OUTPUT ON TERTERM,SO DIDNT NEED ILA.
simu_INTERFACE.pngIam having a problem in implementing the functionality of The "FSM" you suggested please help me out,with the logic part.Block_diagram_with_PS_READ_AND_WRITE.pngBLOCK diagram for PS READ AND WRITE THROUGH PORT APS_FILE_WRITING_PS_AND_READING_FROM_PL_FPGA.pngPS READ AND WRITE OUTPUT IN TERATERM...AS YOU ASKED.READ_WRITE_PS_SIDE.pngPS_PROGRAM FOR READ AND WRITE ..HERE IAM READING THE PL ADDRESS OF AXI BRAM CONTROLLER,AND THUS RESULT IS SHOWN
HERE IS THE  CODE;
module bram_pl(
input clk,
input rst,
input [31:0]din,
input [3:0]wr_addr,
input we,
output wire[31:0]dout
reg[31:0]ram[15:0];
reg [31:0]dout_sig   = 32'd0;
reg [3:0]rd_Addr     = 4'b0000;
reg [3:0]wr_addr_sig = 4'b0000;
reg [2:0]state       = 3'b000;
reg [31:0]din_sig    = 32'd0;
parameter INIT_STATE                 = 3'b000;
parameter RAM_OPERATION              = 3'b001;
parameter READ_TRIGGER_START         = 3'b010;
parameter ADDR_INC                   = 3'b011;
parameter WB                         = 3'b100;
parameter OUTPUT_STATE_TRIGGER_STOP  = 3'b101;
parameter DONE_STATE                 = 3'b110;
assign dout    = dout_sig;
assign wr_addr = wr_addr_sig;
assign din     = din_sig;
always@(posedge clk)
begin
case(state)
INIT_STATE:
 if(!rst)
   state            <=  RAM_OPERATION;
 else
   state            <=  INIT_STATE;
RAM_OPERATION:
 begin
 if(we == 1)
  ram[wr_addr_sig]  <=  din_sig;//data given to Ram,which increments Address(ie;Write Address)
else
 begin
  rd_Addr           <=  wr_addr_sig;//rd_Addr given to Read data
  state             <=  READ_TRIGGER_START;////BRAM operation
end
end
READ_TRIGGER_START:
begin
dout_sig           <=  ram[rd_Addr];//1.)Read data at each and every address
state              <=  ADDR_INC;
end
ADDR_INC:
begin
din_sig           <= din_sig + 32'd1;
wr_addr_sig       <= wr_addr_sig + 4'd1;//2.)Add 1 to it
state             <= WB;
end
WB:
begin
ram[wr_addr_sig]  <=  din_sig;//WRITE BACK
state             <=  OUTPUT_STATE_TRIGGER_STOP;
end
OUTPUT_STATE_TRIGGER_STOP:
begin
dout_sig         <=  ram[wr_addr_sig];///writing of data to output signal
state            <=  DONE_STATE;
end
DONE_STATE:
begin
dout_sig        <= 32'd0;
end
default:
begin
dout_sig        <= 32'd0;
din_sig         <= 32'd0;
end
endcase
end
endmodule
TESTBENCH TOO;
module TB_BRAM();
reg clk;
reg [31:0]din;
reg [3:0]wr_addr;
reg rst;
reg we;
wire[31:0]dout;
bram_pl b1 (.clk(clk),.din(din),.wr_addr(wr_addr),.rst(rst),.we(we),.dout(dout));
initial
begin
clk     = 1'b0;
din     = 32'd0;
we      = 1'b0;
wr_addr = 4'd0;
end
always
#5 clk = ~clk;
initial
begin
rst  = 1'b1;
#10;
rst  = 1'b0;
//#70;
//rst  = 1'b1;
//#75;
//rst  = 1'b0;
end
initial
begin
din     = 32'h0a3d70a3;//100mhz
wr_addr = 4'd0;
#100;
din     = 32'h0e560418;//140mhz
wr_addr = 4'd1;
we      = 1'b1;
#100;
din     = 32'h147ae147;//200mhz
wr_addr = 4'd2;
we      = 1'b1;
#100;
din     = 32'h20c49a5;//320mhz
wr_addr = 4'd3;
we      = 1'b1;
#100;
wr_addr = 4'd0;
we      = 1'b0;
#100;
wr_addr = 4'd1;
we      = 1'b0;
#100;
wr_addr = 4'd2;
we      = 1'b0;
#100;
wr_addr = 4'd3;
we      = 1'b0;
#100;
end
endmodule
Re: HERE I WAS GETTING OUTPUT ON TERTERM,SO DIDNT NEED ILA.
PLease help me in the implementation of the functionality of the FSM,as that is the main Hurdle..please look into it @ronnywebers
Good Morning,Sir iam waiting for your Reply..
Advisor ronnywebers
Advisor
@sam007, please be a bit more patient ... I'm probably living in a different time zone, and I don't wake up at night to answer forum questions :-)
1) First of all : the screenshot with the waveforms : is this from your simulator? If so, can you add more 'internal signals' to it, like 'state', so you can see the different states your FSM is going through. Better to put enough signals there, so we can see better what's going on there
2) if you would have used 'enum' to name your states, it will be even more easy to see the states in the simulation output, checkout for example this 5 minute video on how to do this
3) can you tell me what you're trying to accomplish in this part of the code - it looks strange to me, like a 'state' (RAM_OPERATION) inside a 'state' (INIT_STATE) - again, I'm not a Verilog programmer, so this might be correct, but it looks kinda strange to me :
case(state)
INIT_STATE:
 if(!rst)
 else
RAM_OPERATION:
 begin
 if(we == 1)
else
 begin
end
end
5) In your simulation I think your 'we' should be already high when you write the value 'h0a3d70a3'
6) referring to your block diagram : where exactly is this FSM packaged in? Did you build a custom IP with this FSM code inside of it, and named it 'block memory generator' ?? Or are are you just simulating your code and haven't packaged it yet into a custom IP?
1.)sir..since Iam using Verilog ...not SYSTEM verilog..so i think..ENUM is something iam not too familiar using
2.)secondly i have mentioned the internal signals,"current state"...here i have changed the code..and look into the simulation as my DATA_IN_SIG and DATA_OUT_SIG are showing unknown.
3.)i havent used ILA since...my normal simulation isnt coming as expected...please help me in framing that logic,
and tell me what i need to do,in order to correct that...I have shared my code.....
4.) I havent packaged it...since iam checking functionlity....
5.)i have attached the simulation shots and the DUT and testbench...
 6.) Here since you discussed about this logic"you could for example build an FSM that reads the data on each address, adds 1 to it, and writes it back. Then you'll also need something to trigger a 'start' of this caluclation, and optinally signal an end."..i have written that code itself...and there is one code in VHDL which they tried the same logic...please guide me on how to use it...iam attaching that to...
        THANKS IN ADVANCE
        @ronnywebers
//DUT//
module bram_pl(
input clk,
input Rst,
input[31:0]data_in,
input[31:0]address,
input wr_enable,
output wire[31:0] data_out
reg [31:0]data_out_sig            = 32'h00000000;
reg [31:0]data_in_sig             = 32'h00000000;
reg [2:0]current_state            = 3'b000;
reg [31:0]address_wr_sig          = 32'h00000000;
reg [31:0]RAM[1023:0];
reg [31:0]address_rd_sig          = 32'h00000000;
parameter INIT                    = 3'b000;
parameter READING_ADDRESS         = 3'b001;
parameter INC_ADDRESS             = 3'b010;
parameter WRITE_BACK              = 3'b011;
parameter DONE                    = 3'b100;
assign data_out                   = data_out_sig;
assign data_in                    = data_in_sig;
assign address                    = address_rd_sig;
begin
case(current_state)
INIT:
if(Rst == 1)
 begin
  current_state        <= INIT;
  data_out_sig         <= 32'h00000000;
end
else
 current_state         <= READING_ADDRESS;
READING_ADDRESS:
 begin
  RAM[address_rd_sig]  <=  data_in_sig;
  data_out_sig         <=  RAM[address_rd_sig];
  current_state        <=  INC_ADDRESS;
 end
INC_ADDRESS:
 begin
  data_in_sig          <= data_in_sig + 32'h04000004;
  address_rd_sig       <= address_rd_sig + 32'h00000004;
  current_state        <= WRITE_BACK;
 end
WRITE_BACK:
  if(wr_enable == 1)
else
  begin
  address_wr_sig       <= address_rd_sig;
  current_state        <= DONE;
 end
DONE:
 begin
  data_out_sig         <= RAM[address_wr_sig];
  end
default:
 begin
  address_rd_sig       <=  32'h00000000;
 end
 endcase
 end
endmodule
//TB//
module TB_BRAM();
reg clk;
reg [31:0]data_in;
reg [31:0]address;
reg wr_enable;
reg Rst;
wire[31:0]data_out;
bram_pl b1 (.clk(clk),.data_in(data_in),.address(address),.Rst(Rst),.wr_enable(wr_enable),.data_out(data_out));
initial
begin
clk     = 1'b0;
end
always
#5 clk = ~clk;
initial
begin
Rst  = 1'b1;
#10;
Rst  = 1'b0;
//#70;
//rst  = 1'b1;
//#75;
//rst  = 1'b0;
end
initial
begin
wr_enable = 1'b1;
#35;
wr_enable = 1'b0;
#50;
wr_enable = 1'b1;
#75;
wr_enable = 1'b0;
#105;
end
endmodule
Advisor ronnywebers
Advisor
@sam007, I'd try to find a verilog tutorial that first gives you a working module and testbench, so you can start from that. I googled a bit and found the one attached. I really think you should calm down and have a look at that tutorial first. you'll win back that time later.
Looking at that code quickly, I think at least one issue is here :
I think you should end your init state here. If you do so, you'll need to remove one 'end' statement at the bottom of your code.
Then next, your testbench looks incomplete - you should define signals for all inputs (stimuli) of your DUT, these are :
input clk,
input Rst,
input[31:0]data_in,
input[31:0]address,
input wr_enable,
If I'm correct, you're not defining anything for data_in and address, hence the red signals ..
Also, look at your simulation : next_state shows that immediately after reset ends, you go from 0 -> 1 -> 2 -> 3 -> 4, and you seem to stay in '4' forever ... ? So there's one of your issues I guess, but to be honest, your design looks unclear to me ...
try to draw your system on paper :  start drawing an FSM block and a BRAM block, and see how these connect. Then create 2 verilog source files, one for the BRAM, one for the FSM, then hook both up in a testbench. I'm confused by your files : you also showed a screenshot of 'counter_data.vhd' which is a VHDL file... I don't see how / where that is connected to your FSM or BRAM ...?
Also, check UG937 - Logic Simulation Tutorial - it might take you a few hours to go through this, but you'll have a good verilog code and testbench example.
I really recommend you reading a good Verilog book that approaches things in a modular way, you'll win all that time back. A good book IMHO is from Pong P. Chu, it's rather old, but still a good one to start with. He has many other good books.
i have done changes,here it goes
1.) I have added that "end" in the INIT state,and thus there is a more Systematic flow to the FSM.
2.)i have defined the "Data_in" and "Address values" in the Testbench. I have a Question... is it Required to define these values in the DUT.(ie;0a3d70a3,values so on...) TESTBENCH ATTACHED TOO.
3.) In the simulation it is not getting stuck at that "4" state...but atleast DATA_IN and DATA_OUT are kindof Matching..where DATA_IN is being incremented,and DATA_OUT Increment occurs..(SIMULATION SNAPSHOT ATTACHED)
4.) I Have attached a changed version of this code.(DUT AND TESTBENCH).So i want to understand one thing...BRAM is just basic READ/WRITE..right? or is there something else more to be added within the bram.
Secondly,this statement in the DUT
address_rd_sig <= address_rd_sig + 4'd4;
is the logic of the FSM that you mentioned ..quoted by Yourself" FSM that reads the data on each address, adds 1 to it, and writes it back." is this that logic....
here i have Written "BRAM and the Logic which you mentioned in one FSM"..is it the right thing what iam doing?
or should i  just write one source for Conventional BRAM and one FSM...for the logic that is mentioned.. by you.
separtely
5.) you said to make two files one for FSM and one for BRAM them separtely,is doing them together an issue...please let me know on this..........
6.)iam going through Your references of FSM pdf which you sent,Verilog book,and logic simulation...i now what path i have to follow...it will take time..but good in long term.
7.)finally can you refer me a good soure for basic digital logic....for LOGIC SYNTHESIS...and hardware analysis?
let me know on the fsm and bram..confusion i have
        THANKS YOU        ADVANCE
        @ronnywebers
//DUT//
module bram_pl(
input clk,
input Rst,
input[31:0]data_in,
input[3:0]address,
input wr_enable,
reg [3:0]address_wr_sig           = 4'd0;
reg [31:0]RAM[15:0];
reg [3:0]address_rd_sig           = 4'd0;
//assign data_in                    = data_in_sig;
//assign address                    = address_rd_sig;
begin
 data_in_sig           <= data_in;
 address_rd_sig        <= address;
case(current_state)
INIT:
 begin
if(Rst == 1)
 begin
end
else
 end///end has been added....to end the "INIT" state ..as the FSM will be stuck in the same state.
READING_ADDRESS:
 begin
 end
INC_ADDRESS:
 begin
 end
WRITE_BACK:
  if(wr_enable == 1)
  begin
  end
else
  begin
 end
DONE:
 begin
  current_state        <= INIT;/////////Had Written "DONE"but in simulation,FSM was stuck..so its going back to 1(READING_ADDRESS)
  end
default:
 begin
  address_rd_sig       <=  4'd0;
 end
 endcase
 end
endmodule
//TB//
module TB_BRAM();
reg clk;
reg [31:0]data_in;
reg [3:0]address;
reg wr_enable;
reg Rst;
wire[31:0]data_out;
initial
begin
clk     = 1'b0;
end
always
#5 clk = ~clk;
initial
begin
Rst  = 1'b1;
#10;
Rst  = 1'b0;
//#70;
//rst  = 1'b1;
//#75;
//rst  = 1'b0;
end
initial
begin
data_in   = 32'h0a3d70a3;
address   = 4'd0;
wr_enable = 1'b1;
#100;
data_in   = 32'h0e560418;
address   = 4'd1;
wr_enable = 1'b1;
#100;
data_in   = 32'h147ae147;
address   = 4'd2;
wr_enable = 1'b1;
#100;
data_in   = 32'h20c49ba5;
address   = 4'd3;
wr_enable = 1'b1;
#100;
address   = 4'd0;
wr_enable = 1'b0;
#100;
address   = 4'd1;
wr_enable = 1'b0;
#100;
address   = 4'd2;
wr_enable = 1'b0;
#100;
address   = 4'd3;
wr_enable = 1'b0;
#100;
end
endmodule
simulation_snapshot_1.pngINITIALLY IT SHOWS UNKNOWN..WHY SO..simulation_snapshot_2.pngAND ALSO IN BETWEEN TOO?WHY?simulation_snapshot_3.pngAND THEN IT INCREMENTS AS SHOWN IN DATA_OUT...IS THAT PART CORRECT?
Sir,reply me whenever you are free...waiting for your Reply
sir there is increment in data_out values because of the "data_in <= data_in + 32'h04000004"new_simu.pnglet me know on this!!,is this simulation,correct..?let me know...i have attached the code were "i have combined both the BRAM and the FSM in one verilog file". sorry for asking ..stupid questions,at the start..
        THANKS IN        ADVANCE
        @ronnywebers
CODE attached here
module bram_pl(
input clk,
input Rst,
input[31:0]data_in,
input[3:0]address,
input wr_enable,
//reg [31:0]data_out_sig            = 32'h00000000;
//parameter DONE                    = 3'b100;
begin
case(current_state)
INIT:
 begin
if(Rst == 1)
 begin
//  data_out_sig         <= 32'h00000000;
end
else
READING_ADDRESS:
 begin
//  data_out_sig         <=  RAM[address_rd_sig];
 end
INC_ADDRESS:
 begin
 end
WRITE_BACK:
  if(wr_enable == 1)
  begin
 end
//DONE:
// begin
//  data_out_sig         <= RAM[address_wr_sig];
//  current_state        <= INIT;/////////Had Written "DONE"but in simulation,FSM was stuck..so its going back to 1(READING_ADDRESS)
//  end
default:
 begin
  data_in_sig          <=  32'h00000000;
 end
 endcase
 end
 assign data_out       = RAM[address_wr_sig];
endmodule
here the simulation...iam not sure whats going ...its incremneted the dout + 4 ...from the input data...just verify this
THANKS IN ADVANCE,@ronnywebersupdated_simu.pngi need clarification on this..as in whether the logic simulation is correct? or not?
Advisor ronnywebers
Advisor
@sam007, not yet sure what's going on, it incremented the lowest byte with 4 and highest byte with 4 too..
again, I think you should design in a more modular way :
create 1 separate file which is the RAM, see for example UG901 (Synthesis guide) on how to infer RAM in code. Later, you will probably replace this RAM module with the Block Memroy Generator + dual port RAM IP in the block diagram. Separating the RAM into 1 module will also simplify your understanding of what is happening.
So in UG901 in the link I gave you, check on page 111 for 'rams_sp_rf_rst.v', and build yourself a separate memory module. (there's are many ways to build a RAM shown in that chapter, single-port, dual-port, and so on. But start with a simple single-port block ram).
Then create a 2nd file for your FSM. Think of your FSM as a 'controller' that connects to the RAM (like a microprocessor). Draw a block diagram of your FSM module connecting to that single port RAM module (connect the ports like dout, we, addr, from the FSM block to the memory). So you need to see 2 blocks on paper, 1 FSM block, 1 RAM block, and then a bunch of connections. Your FSM will then generate all the signals to control the operation of that RAM. The RAM is just a 'slave' module to the FSM.
To make these 'connections', create a 3rd file, which will be your testbench. In that testbench, you instantiate and hook up both the RAM module and FSM with each other, and generate stimuli to your FSM (clock, reset, enable) and RAM (clock, reset). The we, data, ... for the RAM are generated by the FSM.
you really need to think modular, and I also think you should hold your breath, step back a little, read a good verilog book, start from some working examples (like UG937 Logic simulation tutorial), and then move on. I'm sorry I cannot help you much with verilog, but if you make a clean block design and think modular, I"m sure you'll get there. Also checkout that UG901 further, chapter 4 shows a lot of coding techniques, also for FSM on page 162
