BSP creation for IP in separate block designs
I am testing out possible ways to make block designs more modular and transportable.  One test I am trying is to separate the microblaze subsystem (with axi interconnect) and peripherals into different block designs.  This would let me use HDL top levels with parameters to include/exclude blocks as needed.
The address portion is easy, in that I can assign the addresses as needed in the microblaze BD.  However, the BSP does not generate with drivers for the peripherals in other blocks.  I'm asking if there is a way to do this, as the imported HDF clearly knows that the other peripherals exist.  Or is this something I should just import manually?
--Dominic
Re: BSP creation for IP in separate block designs
As i guess, TPG Pheripheral is not connected to any Master interface. Pls check it again and try.
Madhu
