Scholar mrbietola
Big Endian Little Endian confusion
i am doing a tcp application in SDK, i use microblaze with AXI Bus.
I see that microblaze endianness is little endian because of the AXI Bus,
in  SDK i see that in the Symbol tab in the compiler option is active the symbol "__BIG_ENDIAN__"
what is the endianness of the platform?
Re: Big Endian Little Endian confusion
When MicroBlaze is configured for AXI, it will use little-endian mode
Akshay
You can find some useeful information in the following AR http://www.xilinx.com/support/answers/45841.html also
Scholar sampatd
MicroBlaze uses Big-Endian or Little-Endian format to represent data, depending on the parameter C_ENDIANNESS
The C_ENDIANNESS parameter is automatically set to little endian when using AXI4, but can be overridden by the user.
Can you attach your SDK workspace here?
Scholar stephenm
The feature to over write the endianess is removed in Vivado. This was in XPS to support the PLB which supports big endian
Scholar mrbietola
I continue to not understand,
i use a free TCP/IP library, it has some controls on the endianness of the platform to do some conversion (htons ntohs) to correctly forward addresses on the network..
#ifdef __BIG_ENDIAN__
#ifndef htons
  #define htons(x) (x)
#endif
#ifndef ntohs
#define ntohs(x) (x)
#endif
#ifndef htonl
#define htonl(x) (x)
#endif
#ifndef ntohl
#define ntohl(x) (x)
#endif
 i see that __BIG_ENDIAN__ is defined,   i see that microblaze is little endian, i see that the application works
where is the trick?    maybe microblaze use some functions to convert from little endian to big endian?
how can i attach my workspace?
You are right. ntoh and hton that you are referring in the below post are a part of xil_io.h that comes along with Standalone BSP. These functions are also a part of the LWIP source code too. You can find the information about these functions in page 38 of UG647 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/oslib_rm.pdf
--Hem
