Block diagram delete wire portion between two intersections
Hello I'm working with Vivado 2018.2. Is there a way to delete wire portion between two intersections without delete the entire wire? Thank you.
Re: Block diagram delete wire portion between two intersections
Try "disconnect pin" from menu opened by right-clicking.
Hi @nuelle85,
thank you very much. This is exactly what I was searching for.
